    Unable to run MM install script with raspbian bookworm
    13 Posts 2 Posters 4.4k Views 2 Watching
    • I Offline
      ijahmc2u
      this is the error that I am getting …
      ReferenceError: primordials is not defined
      at evalmachine.:43:5
      at Object. (/usr/lib/node_modules/npm/node_modules/graceful-fs/fs.js:11:8)
      at Module._compile (node:internal/modules/cjs/loader:1233:14)
      at Module._extensions…js (node:internal/modules/cjs/loader:1287:10)
      at Module.load (node:internal/modules/cjs/loader:1091:32)
      at Module._load (node:internal/modules/cjs/loader:938:12)
      at Module.require (node:internal/modules/cjs/loader:1115:19)
      at require (node:internal/modules/helpers:130:18)
      at Object. (/usr/lib/node_modules/npm/node_modules/graceful-fs/graceful-fs.js:3:27)
      Node.js v20.5.1
      npm installation Done! version=V
      It seems like MagicMirror is already installed.
      To prevent overwriting, the installer will be aborted.
      Please rename the ~/MagicMirror folder and try again.
        sdetweil @ijahmc2u
        @ijahmc2u please don’t do the node20 stuff it messes it all up
        flash the SD card
        boot , configure wifi…
        reboot run my install script
        then add the; ther stuff
        do NOT DO ANY NODE INSTALL . my script will handle all that.
        I 2 Replies Last reply Reply Quote 0
          sdetweil @ijahmc2u
          @ijahmc2u can you show me the ~/install.log
          you flash the SD card
          boot and first thing run my install script
          then add other stuff. opencv… etc
            sdetweil @ijahmc2u
            @ijahmc2u that sounds like the old script
            so do
            sudo apt-get remove nodejs npm -y
            then after
            hash -r
            then node -v
            should be command not found
            • I Offline
              ijahmc2u @sdetweil
              this was a new sd card and new install …
              for some reason it is telling me the log file needs to end in png… jpeg not in .log
              anyway to get ti working I had to do the following
              sudo apt-get update && sudo apt-get install -y ca-certificates curl gnupg
              curl -fsSL https://deb.nodesource.com/gpgkey/nodesource-repo.gpg.key | sudo gpg --dearmor -o /etc/apt/keyrings/nodesource.gpg
              NODE_MAJOR=20
              echo “deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_$NODE_MAJOR.x nodistro main” | sudo tee /etc/apt/sources.list.d/nodesource.list
              sudo apt-get update && sudo apt-get install nodejs -y
              • I Offline
                ijahmc2u @sdetweil
                sorry just lost power for a bit there…
                so to answer your questions this was a fresh install of MM on a new SD card
                no I installed the opencv and dlib first as I have had issues with them in the past so I built them from source…
                while doing some reading I installed nodejs from the steps on their site and then ran your script and now it installed everything and ran pm2 as well … vnc is not working but thats ok for now.
                also note I was trying to upload my install.log but it won’t let me upload a .log file
                • I Offline
                  ijahmc2u
                  admin@rasmm:~ $ node -v
                  v20.8.1
                    sdetweil @ijahmc2u
                    @ijahmc2u hm… but why? should be 20.8.0
                    do
                    n ls
                      sdetweil @ijahmc2u
                      flash the SD card
                      • I Offline
                        ijahmc2u @sdetweil
                        ok will try that
                        • I Offline
                          ijahmc2u @sdetweil
                          ok that worked please close this one … looks like I am having another problem with the module mmm-face-reco-dnn all other modules seem to be installing ok
                            sdetweil @ijahmc2u
                            @ijahmc2u said in Unable to run MM install script with raspbian bookworm:
                            whats the problem there? note that it is using old python, and opencv so there may be impacts… the module hasn’t been updated in quite a while
                            and the install/usage doc is missing a few important words for new users
                            • I Offline
                              ijahmc2u @sdetweil
                              sorry for the late response
                              After installing pipenv I still can’t get the dependencies to be installed seems to look up at the Pipfile.lock and then after some time it spits out a bunch of failure messages
                                sdetweil @ijahmc2u
                                @ijahmc2u I don’t know. I see the author has been working on some changes…
