    Modules duplicate themselves and move in and out
    7 Posts 2 Posters 1.7k Views 2 Watching
      sil3ntstorm
      Hello,
      My monitor is showing me strange things for the second time. The first time at the beginning of the week, restarting didn’t help. Since my monitor restarts every day at 5 a.m., I no longer had the problem the next day, but the next day it was back.
      I can’t explain why it is, does anyone of you know the problem or the solution?
      Some modules are duplicated, sometimes the monthly calendar, sometimes the Google calendar or even the Netatmo and weather module
        MMRIZE @sil3ntstorm
        @sil3ntstorm
        Very mysterious symptom.
        And… The duplicated clocks are displaying different times quite differently! I cannot guess how this could happen.
        Could you share the whole screen? because some modules seem duplicated, but some don’t, and I want to see where the duplications are placed.
        (And your config.js also)
          sil3ntstorm @MMRIZE
          @MMRIZE ```
                  module: 'MMM-WetterOnline',
              header: "Wetter Schama",
          	useHeader: true,
          	city: "hemau",
          	width: "400px",
          	daysTrend: 7,
          	updateIntervalMins: 5,
              module: 'MMM-Tado',
              position: 'bottom_right', // This can be any of the regions.
                  username: 'secret',
                  password: 'secret',
                  updateInterval: 120000
          module: ‘MMM-DWD-WarnWeather’,
          position: ‘top_center’,
          header: ‘Wetterwarnungen’,
          region: ‘Hemau’,
          changeColor: true,
          minutes: false,
          displayRegionName: true,
          displayInnerHeader: false,
          interval: 10 * 60 * 1000, // every 10 minutes
          loadingText: ‘Warnungen werden geladen…’,
          noWarningText: ‘Keine Warnungen’,
          severityThreshold: 1
          module: “MMM-MyCalendar”,
          position: “bottom_left”,
          classes: “default everyone”,
          header: “Upcoming”,
          disabled: false,
          colored: true,
          maximumNumberOfDays: 30,
          maximumEntries: 10,
          fade: false,
          maxTitleLength: 500,
          fetchInterval: 500000,
          useRelativeDates: false,
              dayOfWeekFormat: "dddd",
              timeFormat: "HH:mm",
              dateFormat: "MMMM D",
              joiningWord: "um",
              urgency: 1,
                		url: "secret",
                  		color: "#ffb350"
          		url: "secret",
          		color: "#ff77d4"
               		url: "secret",
          		color: "#00FF00"
          module: ‘MMM-MonthCalendar’,
          position: “top_left”,
          header: “”,
          updateDelay: 5,
          showAdjacentMonths: true
          module: ‘MMM-Netatmo’,
          position: ‘bottom_right’, // the location where the module should be displayed
          header: ‘Netatmo_Station’,
          clientId: ‘secret’, // your app id
          clientSecret: ‘secret’, // your app secret
          refreshToken: ‘secret’,
          accessToken: “secret”,
          updateIntervalAirQuality: 600, // in secondes = every 30 minutes
          updatesIntervalDisplay: 60, //refresh internal
          lastMessageThreshold: 600, // in seconds (10 minutes)
          horizontal: false,
          horizontalOverflow: false,
          windUnit: “KT”, // Possible “KMH”, “MPH”, “MS”, “BFT”, “KT”
          displayWindInOutdoor: false,
          displayRainInOutdoor: false,
          showLastMessage: true,
          showDataIcon: true,
          showDataHeader: true,
          showModuleStatus: true,
          showModuleFirmware: true,
          refreshInterval: 3,
          moduleOrder: [ “Garten”, “Wintergarten”, “Wohnzimmer”, “Badezimmer”, “Schlafzimmer” ],
            MMRIZE @sil3ntstorm
            @sil3ntstorm
            It seems not all the config (because, you probably have news module.)
            Do you have any module for position/page control?
              sil3ntstorm @MMRIZE
              @MMRIZE Yes, I have the standard news module running. I don’t have a module for position/lateral control.
                MMRIZE @sil3ntstorm
                @sil3ntstorm
                I have never seen that symptom and have no idea to guess what happened.
                Here are general methods to deal with the error;
                1. Backup your current config.js
                2. Try the original config. You can restore it from config.js.example
                • If you still have an issue even with the original config, one of MM/OS/HW might be the reason.
                  • Remove MM, then reinstall clearly again;
                  • Not solved with newly installed MM; Format your SD card and reinstall OS. Then, reinstall MM.
                  • Still not solved; your HW might have some issues.
                • If you have no issue with the original, the issue probably came from one of the 3rd party modules;
                  • Try adding the module one-by-one on the original config / Or you can remove the suspicious module one-by-one from your config.
                  sil3ntstorm
                  Thanks for your help, I think I found the error. It was the module: weather online, when I hidden it, the other modules were in the right place and not moved.
                  I hope it doesn’t happen again :-)
                  Now I have to choose another module for my weather
