    MM current version on Raspberry Pi 5 cannot turn off monitor
    53 Posts 9 Posters 34.1k Views 9 Watching
      sdetweil @liminal1
      @liminal1 note that rapios on pi4 and 5 use a new display manager called Wayland.
      so all the commands for display MGMT have changed. see the commands posted above.
      or set the os back to x11. see the raspi-config command
      • L Offline
        liminal1 @sdetweil
        @sdetweil said in MM current version on Raspberry Pi 5 cannot turn off monitor:
        I did try those commands, they are not working for me. Maybe I need more context for that (which is essentially what I was asking for :) Or I switch back to a slower and less efficient display model that negates having a Pi 5. Is that a correct asumption?
        Maybe I wasn’t clear, but Im just asking if anyone does have it working on the Pi 5 with Bookworm. What did you use and how did you do it?
        Thank you :)
        S 1 2 Replies Last reply Reply Quote 0
          sdetweil @liminal1
          @liminal1 the posts above say it was working on bookworm.
          https://forum.magicmirror.builders/post/114283
          • 1 Offline
            1a2a3a @liminal1
            @liminal1 doesn’t matter 4 or 5. As long as bookworm wayland, it’s working fine. For what’s worth, I’m on a 5.
            • L Offline
              liminal1 @sdetweil
              If I create that script and run it, it brings up a logon page :(
              • L Offline
                liminal1 @1a2a3a
                @1a2a3a
                @1a2a3a said in MM current version on Raspberry Pi 5 cannot turn off monitor:
                Thanks mate :)
                But what is working fine? Which part :)
                Im quite new to the Pi
                  sdetweil @liminal1
                  @liminal1 that makes no sense.
                  you are running this from a terminal window, right
                  ctrl-alt-t on the desktop.
                  nothing login related there
                  • L Offline
                    liminal1 @sdetweil
                    Yes
                    Its a touch screen, what does this do?
                    Not sure what you mean?
                      sdetweil @liminal1
                      @liminal1 the terminal window has nothing to do with login.
                      your system should boot to the desktop
                      then open a terminal window
                      and type the commands above
                      or use an ssh session from your pc
                      • L Offline
                        liminal1 @sdetweil
                        Yes,
                        So this is what is happening to me when I try the script or the command
                        https://forums.raspberrypi.com/viewtopic.php?p=2196846&hilit=wlr+randr#p2196846
                        • 6
                        • 5 / 6
