    GPIO PIN on 3b not working
    6 Posts 3 Posters 1.0k Views 3 Watching
    • F Offline
      faspina1
      I have had a rpi in place running a python written program that displays several web pages in a kiosk mode under chromium.
      A customize version of this project
      https://www.instructables.com/Raspberry-Pi-Wall-Mounted-Google-Calendar/
      I have 34simple push buttons (plunger buttons each with only two terminals) all wired to the pi (One pin to GPIO the other to GND) . It works fine. Pyton code below.
      Initialization code
      GPIO.setmode(GPIO.BCM)
      GPIO.setup(19, GPIO.IN, pull_up_down=GPIO.PUD_UP)
      GPIO.setup(20, GPIO.IN, pull_up_down=GPIO.PUD_UP)
      GPIO.setup(21, GPIO.IN, pull_up_down=GPIO.PUD_UP)
      GPIO.setup(26, GPIO.IN, pull_up_down=GPIO.PUD_UP)
      Variable loaded
          input_state_back = GPIO.input(19)
          input_state_forward = GPIO.input(20)
          input_state_view = GPIO.input(26)
          input_state_change = GPIO.input(21)
      Logic to test
      if input_state_change == True
        do some stuff
      The code has been running on the pi 5 years, great.
      So I have another PI that I built with MM, getting the screen like I want it to replace this one in the kitchen.
      Take the SD card out of the test box put in in the kitchen pi, crank up MM and then use MMM-Buttons to configure the pins. The last step in my move to replace it.
      I got nothing
      pins will not register when I press them
      MMM-Button Config below. I am watching for events in the log and Ihave notification on the screen. I have successfully hooked up MQTT to receive notification as well. I have gooled all over and I can’t figure out why the buttons will not work when wired up the same way.
      			module: 'MMM-Buttons',
      				buttons: [
      						pin: 21,
      						name: "User Present",
      						shortPress: {
      							notification: "REMOTE_ACTION",
      							payload: {action: "USER_PRESENCE", value: true}
      						longPress: {
      							payload: {action: "REFRESH"}
      						pin: 19,
      						shortPress: {
      						longPress: {
      						pin: 20,
      						shortPress: {
      						longPress: {
      						pin: 26,
      						shortPress: {
      						longPress: {
      Any body have any idea what is going on?
      S karsten13K 2 Replies Last reply Reply Quote 0
        sdetweil @faspina1
        @faspina1 do you have things connected correctly? mmm-buttons uses the bcm numbering
        https://raspberrypi.stackexchange.com/questions/12966/what-is-the-difference-between-board-and-bcm-for-gpio-pin-numbering/12967#12967
        I don’t know what you did before
        • F Offline
          faspina1 @sdetweil
          @sdetweil Yes. They were working and continue to work with my other program I never moved the , they are mounted and connect to the RPI.
          What I have noticed is that after powering off , i have to run a python test program on each of the 4 pins. Then they start suddenly working on MM.
          I have verified this twice cause I thought I was nuts. I may still be nuts but that is exactly what is happening.
          the 4 push buttons i have configured for USER_PRESENCE, REFRESH, MONITORTOGGLE, and RESTART
          Pins 26,21,19,20
          • karsten13K Offline
            karsten13 @faspina1
            @faspina1
            did you enable the gpio stuff via raspi config on the new pi?
              sdetweil @faspina1
              @faspina1 I have seen a couple other users report the same thing. I do not know why.
              I looked thru raspi-config, and only saw remote GPIO.
              you might try that
              sudo raspi-config
              interfaces
              as a short term, you could add running the test python as part of the mm startup script
              if you used my install script, and use pm2 to launch mm , that script is
              ~/MagicMirror/installers/mm.sh
              • F Offline
                faspina1 @sdetweil
                @sdetweil I may add the python code to the start of the script. Enable the pins in Python and then read them . See if that works.
                I see that others have reported as well
