    Weekly Recurring Calendar entries show once three weeks ahead
    6 Posts 2 Posters 837 Views 2 Watching
    • C Offline
      cgreever1
      I have a weekly recurring calendar event but it only seems to show the last occurrence on the calendar not each individual Saturday event.
      Here’s the ICS
      BEGIN:VEVENT
      DTSTART;TZID=America/New_York:20240106T094000
      DTEND;TZID=America/New_York:20240106T102000
      RRULE:FREQ=WEEKLY
      DTSTAMP:20240108T162307Z
      UID:BC956B9B-76BD-4722-BB7B-F1E9F312157A
      CREATED:20240101T172829Z
      LAST-MODIFIED:20240108T151551Z
      SEQUENCE:0
      STATUS:CONFIRMED
      SUMMARY:Henry swim at Y
      TRANSP:OPAQUE
      X-APPLE-CREATOR-IDENTITY:com.apple.mobilecal
      X-APPLE-CREATOR-TEAM-IDENTITY:0000000000
      END:VEVENT
        sdetweil @cgreever1
        @cgreever1 I don’t see any problem using that as the only entry in an ics.
        what is the config of your calendar
        you can also turn on debug for the calendar module, but adding
        “DEBUG”
        to the logLevel:[] list at the top of config.js
        I would be interested in seeing the debug output, here is on my system
        using the latest 2.26 parser and rrule.
        Processing entry...
        [11.01.2024 15:22.06.567] [DEBUG] Event:
        {"type":"VEVENT","params":[],"start":"2024-01-06T14:40:00.000Z","datetype":"date-time","end":"2024-01-06T15:20:00.000Z","rrule":{"_cache":{"all":false,"before":[],"after":[],"between":[]},"origOptions":{"tzid":"America/New_York","dtstart":"2024-01-06T14:40:00.000Z","freq":2},"options":{"freq":2,"dtstart":"2024-01-06T14:40:00.000Z","interval":1,"wkst":0,"count":null,"until":null,"tzid":"America/New_York","bysetpos":null,"bymonth":null,"bymonthday":[],"bynmonthday":[],"byyearday":null,"byweekno":null,"byweekday":[5],"bynweekday":null,"byhour":[14],"byminute":[40],"bysecond":[0],"byeaster":null}},"dtstamp":"2024-01-08T16:23:07.000Z","uid":"BC956B9B-76BD-4722-BB7B-F1E9F312157A","created":"2024-01-01T17:28:29.000Z","lastmodified":"2024-01-08T15:15:51.000Z","sequence":"0","status":"CONFIRMED","summary":"Henry swim at Y","transparency":"OPAQUE","APPLE-CREATOR-IDENTITY":"com.apple.mobilecal","APPLE-CREATOR-TEAM-IDENTITY":"0000000000"}
        [11.01.2024 15:22.06.567] [DEBUG] start: Sat Jan 06 2024 08:40:00 GMT-0600 (Central Standard Time)
        [11.01.2024 15:22.06.567] [DEBUG] end:: Sat Jan 06 2024 09:20:00 GMT-0600 (Central Standard Time)
        [11.01.2024 15:22.06.567] [DEBUG] duration: 2400000
        [11.01.2024 15:22.06.567] [DEBUG] title: Henry swim at Y
        [11.01.2024 15:22.06.568] [DEBUG] Search for recurring events between: Thu Jan 11 2024 15:22:06 GMT-0600 (Central Standard Time) and Thu Jan 09 2025 23:59:59 GMT-0600 (Central Standard Time)
        [11.01.2024 15:22.06.607] [DEBUG] Title: Henry swim at Y, with dates: ["2024-01-13T13:40:00.000Z","2024-01-20T13:40:00.000Z","2024-01-27T13:40:00.000Z","2024-02-03T13:40:00.000Z","2024-02-10T13:40:00.000Z","2024-02-17T13:40:00.000Z","2024-02-24T13:40:00.000Z","2024-03-02T13:40:00.000Z","2024-03-09T13:40:00.000Z","2024-03-16T13:40:00.000Z","2024-03-23T13:40:00.000Z","2024-03-30T13:40:00.000Z","2024-04-06T13:40:00.000Z","2024-04-13T13:40:00.000Z","2024-04-20T13:40:00.000Z","2024-04-27T13:40:00.000Z","2024-05-04T13:40:00.000Z","2024-05-11T13:40:00.000Z","2024-05-18T13:40:00.000Z","2024-05-25T13:40:00.000Z","2024-06-01T13:40:00.000Z","2024-06-08T13:40:00.000Z","2024-06-15T13:40:00.000Z","2024-06-22T13:40:00.000Z","2024-06-29T13:40:00.000Z","2024-07-06T13:40:00.000Z","2024-07-13T13:40:00.000Z","2024-07-20T13:40:00.000Z","2024-07-27T13:40:00.000Z","2024-08-03T13:40:00.000Z","2024-08-10T13:40:00.000Z","2024-08-17T13:40:00.000Z","2024-08-24T13:40:00.000Z","2024-08-31T13:40:00.000Z","2024-09-07T13:40:00.000Z","2024-09-14T13:40:00.000Z","2024-09-21T13:40:00.000Z","2024-09-28T13:40:00.000Z","2024-10-05T13:40:00.000Z","2024-10-12T13:40:00.000Z","2024-10-19T13:40:00.000Z","2024-10-26T13:40:00.000Z","2024-11-02T13:40:00.000Z","2024-11-09T13:40:00.000Z","2024-11-16T13:40:00.000Z","2024-11-23T13:40:00.000Z","2024-11-30T13:40:00.000Z","2024-12-07T13:40:00.000Z","2024-12-14T13:40:00.000Z","2024-12-21T13:40:00.000Z","2024-12-28T13:40:00.000Z","2025-01-04T13:40:00.000Z"]
        here is the single entry ics , you can save this as a file and use a url like
        url: "http://localhost:mm_port_from_config.js/modules/default/calendar/xxxx.ics
        where xxx is the filename u save it as
        BEGIN:VCALENDAR
        BEGIN:VEVENT
        RRULE:FREQ=WEEKLY
        SEQUENCE:0
        STATUS:CONFIRMED
        TRANSP:OPAQUE
        END:VEVENT
        END:VCALENDAR
          @cgreever1 the default is 10 entries on the calendar list, so if other events consume some of the 10, then only a few of these (maybe just 1) will be shown
          • C Offline
            cgreever1 @sdetweil
            @sdetweil the recurring entries do display, just 3 weeks in the future, but skips a couple Saturdays where they should display first.
              sdetweil @cgreever1
              @cgreever1 ok, go back to the prior parser
              cd~/MagicMirror
              npm install node-ical@0.16.1
              C 1 Reply Last reply Reply Quote 1
              • C Offline
                cgreever1 @sdetweil
                @sdetweil said in Weekly Recurring Calendar entries show once three weeks ahead:
                The parse change seems to have corrected the issue. Thank you.
