    Default Weather Module Icon Position
    38 Posts 4 Posters 14.3k Views 4 Watching
      sdetweil @greedyvegan
      @greedyvegan said in Default Weather Module Icon Position:
      changing the classes name didn’t work for me, my custom name gets ignored
      you noticed the dot in front of the class name , right?
      . means element class (html class="foo", .foo)
      # means element id  (html id="module_0_clock", #module_o_clock)
      nothing means html element (html img, body, div...)
      in MM if you want to select elements in A module, then you would select the content starting with its id (#module_…) its classname (.modulename) or one of the classes specified in the classes:“xxx yyy”, property for that module
      • G Offline
        greedyvegan @sdetweil
        yes, other modules are easier to me because it’s only one focus
        nothing means html element (html img, body, div…)
        this confused me
        believe me, I’m trying to understand.
        I’m also trying everything I read/see for hours before reaching out for help
        in config, I chose to uniquely identify the two weather “classes”
        however the developer window mentions “class”
        it also says “class=module weather weather” for both weather modules.
        Screenshot 2024-03-31 at 5.31.20 PM.png I think THIS is why modifying one modifies both.
        the weather.js file says .currentWeather & .forecastWeather
        the weather.css file doesn’t differentiate current & forecast classes. I’ve even read the current & forecast njk files for individual class indicators…
        in custom.css I’m trying any and everything I see to individually identify and separate #module_5_weather from #module_6_weather
        I feel like my focus is in the wrong place(s) and i’m overlooking something extremely simple
          @greedyvegan show me the config for the two modules , xxx out the api key
          copy paste, dont change anything else
          • G Offline
              @greedyvegan ok, the ‘classes’ property in this case is an mm config option NOT a module config option.
              so it goes outside of the config:{} section, along with position and header
              see these options in the doc
              https://docs.magicmirror.builders/modules/configuration.html#example
              • G Offline
                @sdetweil said
                the ‘classes’ property goes outside of the config:{} section, along with position and header
                I knew it
                thank you very much, I’ll play around with this in a few
                  @greedyvegan note that modules can also define properties with the same names as we use for mm properties. so one has to check carefully. ive only made this mistake a hundred times…
                  • G Offline
                    @sdetweil lol noted
                    • 4 / 4
