    MMM-weconnectid with 2 accounts
    20 Posts 2 Posters 9.5k Views 2 Watching
    • C Offline
      chrisfr1976
      We have two electric VW and two we-connect accounts. So I‘ve tried to get another instance running on my mirror, but it does not work. If I set a module on disable=true and the other on false in the config.js I can decide which car we can see.
      So I made a workaround today with two config files which are copied in a circle and the refresh of electron is done with xdotool. All that is in a shell script which starts every 10 minutes with a cronjob. A quite dirty way, but we can see the battery status of both cars one after another :)
      Has anyone found a smarter way? I also tried to do a refresh only on the MMM-weconnectid module but my coding skills are still not the best to include updateDOM or whatever to the js or json. I‘ve found a lot hits with Google and some into this direction in this forum the but nothing was explained in a simple way.
      Does someone know a command to convice electron to reload just a specific module? Could be so easy from my newbie point of view 😉
      Cheers, Chris
      Regards, Chris.
        sdetweil @chrisfr1976
        @chrisfr1976 ok, fixed
        the author has accepted these fixes too
        do this
        git checkout main
        git pull
        the SoC value was not copied… don’t know where that went as I didn’t change that block. anyhow fixed
        images, I made a sub folder by module instance… these should be correct now
          @chrisfr1976 the other approach is to copy and rename the module. and change the register to match
          if u can wait til tomorrow, I will update the module to support multiple instances
          • C Offline
            chrisfr1976 @sdetweil
            @sdetweil Wow, sure I can wait. But I’m already excited :-)
            Regards, Chris.
              @chrisfr1976 try this
              cd to the module folder
              git fetch origin pull/6/head:test_multi
              git checkout test_multi
              then in config.js you can use multiple instances of this module with different config settings…
              to go back to the old code if there is a problem
              git checkout main
              I don’t have a vehicle so I cant test it. no code logic was changed.
              I submitted this as a change request to the module author…
              if he accepts it, you would (in the module folder)
              git checkout main
              git pull
              • C Offline
                @sdetweil unfortunately it works just a little.
                My Mirror Display
                I can see two modules the first time on my screen but I can’t see the SoC and the loaded pictures shows the same car. That is clear for me when I check the module.js file. But 2 different cars are loaded what can be seen on the run kilometers.
                So your approach works in general to show the module twice. Thank you for that. That might be helpful for other modules, too.
                But to get the MMM-weconnectid fully working there needs to be some more coding in the module.js to be done. Python grabs the information I think since I see no errors or strange things in the log.
                Unfortunately I’m a mechanical engineer who just starts with some very simple coding. I can’t fix that.
                But again thanks a lot for your support and time you’ve spent!
                Chris.
                Regards, Chris.
                S 3 Replies Last reply Reply Quote 0
                  @chrisfr1976 each module 1 at a time works ok?
                  what is soc? state of charge?
                    @chrisfr1976 yes I see the issue. give me a little time.
                      @chrisfr1976 bug, sorry, he accepted code, but its broken
                      do this
                      git checkout main
                      git fetch origin pull/7/head:test_multi-2
                      git checkout test_multi-2
                      then try again
                        @chrisfr1976 said in MMM-weconnectid with 2 accounts:
                        not mine. it’s the official way to support multiple instances.
                          @chrisfr1976 he has accepted that last pull request, so
                          git checkout main
                          git pull
                          try again
                            @chrisfr1976 did you see my note about an update?
                            • C Offline
                              @sdetweil Hello, yes, sorry for that delay. Yesterday I was out with my company colleagues :clinking_beer_mugs:
                              I’ve just tested the configuration:
                              1. same module, twice in the config
                              2. my copied module with new name with the original module together
                              then both versions with “git checkout main” and for doublecheck your “git checkout test_multi-2”.
                              And unfortunately without success. For Option 1 it stops with “loading…”. For Option 2 I get 1 car shown without any information from VW and the other stops also with “loading…” on the screen.
                              In the logs I just get this:
                              0|mm  | [22.02.2024 19:12.02.704] [LOG]   Got data from weconnectid for VIN WVWZZZE1ZNP0339xx
                              0|mm  | [22.02.2024 19:12.07.203] [LOG]   Got data from weconnectid for VIN WV2ZZZEB5PH0306xx
                              No Errors.
                              So same issue as last time. :crying_face:
                              Regards, Chris.
                                @chrisfr1976 ok.
                                if you are willing to share your config via private message so i can run the module here.
                                maybe there is a syntax error
                                open the developers window, ctrl-shift-i,
                                select the console tab, and put we in the filter field
                                  @chrisfr1976 thanks for your trust
                                  do this
                                  git checkout main
                                  git fetch origin pull/8/head:test_multi-3
                                  git checkout test_multi-3
                                  and try again 1 instance and then both
                                  C 2 Replies Last reply Reply Quote 0
                                  • C Offline
                                    @sdetweil Okay, nearly okay. I see the module twice on the screen. The following issues are on my Mirror:
                                    • SoC for both cars is 0% - main point of interest :-)
                                    • The pictures are the same (it is stored in the same folder with the same name. That is the reason for sure.) - not really needed
                                    • My Calendar Ext3 stays empty. All events are broadcasted without any error. That is something in behind. I had that before when both modules (the original and my copy if both had enabled=true set). No error in the logs or any entry that is new for me.
                                    Regards, Chris.
                                    • C Offline
                                      Short update: CalendarExt3 is now okay. Maybe it needed just some more time.
                                      And the SoC is just missing. The remaining km-range is there. I checked it in the cars. The value is correct.
                                      Regards, Chris.
                                        @chrisfr1976 pictures. I think that comes back on the API. let me check.
                                        soc… also let me check.
                                        ext3. yes, as it is getting data from the default calendar, he is trying not to flash the display too many times. some calendars can take 10 seconds to process with all the old dead entries. he doesn’t know(altho he could! hmmm)
                                        you can change the Ext3 wait time if you know how long it takes roughly.
                                          do this
                                          git checkout main
                                          git pull
                                          • C Offline
                                            @sdetweil Wow, thank you so much! Perfect :folded_hands: :grinning_face_with_big_eyes:
                                            Regards, Chris.
                                              @chrisfr1976 awesome… thanks for the feedback…
