    MMM-weconnectid with 2 accounts
    20 Posts 2 Posters 8.8k Views 2 Watching
      sdetweil @chrisfr1976
      @chrisfr1976 the other approach is to copy and rename the module. and change the register to match
      if u can wait til tomorrow, I will update the module to support multiple instances
        chrisfr1976 @sdetweil
        @sdetweil Wow, sure I can wait. But I’m already excited :-)
        Regards, Chris.
          @chrisfr1976 try this
          cd to the module folder
          git fetch origin pull/6/head:test_multi
          git checkout test_multi
          then in config.js you can use multiple instances of this module with different config settings…
          to go back to the old code if there is a problem
          git checkout main
          I don’t have a vehicle so I cant test it. no code logic was changed.
          I submitted this as a change request to the module author…
          if he accepts it, you would (in the module folder)
          git checkout main
          git pull
            @sdetweil unfortunately it works just a little.
            My Mirror Display
            I can see two modules the first time on my screen but I can’t see the SoC and the loaded pictures shows the same car. That is clear for me when I check the module.js file. But 2 different cars are loaded what can be seen on the run kilometers.
            So your approach works in general to show the module twice. Thank you for that. That might be helpful for other modules, too.
            But to get the MMM-weconnectid fully working there needs to be some more coding in the module.js to be done. Python grabs the information I think since I see no errors or strange things in the log.
            Unfortunately I’m a mechanical engineer who just starts with some very simple coding. I can’t fix that.
            But again thanks a lot for your support and time you’ve spent!
            Chris.
            Regards, Chris.
            S 3 Replies Last reply Reply Quote 0
              @chrisfr1976 each module 1 at a time works ok?
              what is soc? state of charge?
                @chrisfr1976 yes I see the issue. give me a little time.
                  @chrisfr1976 bug, sorry, he accepted code, but its broken
                  do this
                  git checkout main
                  git fetch origin pull/7/head:test_multi-2
                  git checkout test_multi-2
                  then try again
                    @chrisfr1976 said in MMM-weconnectid with 2 accounts:
                    not mine. it’s the official way to support multiple instances.
                      @chrisfr1976 he has accepted that last pull request, so
                      git checkout main
                      git pull
                      try again
                        @chrisfr1976 did you see my note about an update?
