    MMM-weconnectid with 2 accounts
    20 Posts 2 Posters 9.8k Views 2 Watching
      @chrisfr1976 did you see my note about an update?
      C 1 Reply Last reply
        chrisfr1976 @sdetweil
        @sdetweil Hello, yes, sorry for that delay. Yesterday I was out with my company colleagues :clinking_beer_mugs:
        I’ve just tested the configuration:
        1. same module, twice in the config
        2. my copied module with new name with the original module together
        then both versions with “git checkout main” and for doublecheck your “git checkout test_multi-2”.
        And unfortunately without success. For Option 1 it stops with “loading…”. For Option 2 I get 1 car shown without any information from VW and the other stops also with “loading…” on the screen.
        In the logs I just get this:
        0|mm  | [22.02.2024 19:12.02.704] [LOG]   Got data from weconnectid for VIN WVWZZZE1ZNP0339xx
        0|mm  | [22.02.2024 19:12.07.203] [LOG]   Got data from weconnectid for VIN WV2ZZZEB5PH0306xx
        No Errors.
        So same issue as last time. :crying_face:
        Regards, Chris.
          sdetweil @chrisfr1976
          @chrisfr1976 ok.
          if you are willing to share your config via private message so i can run the module here.
          maybe there is a syntax error
          open the developers window, ctrl-shift-i,
          select the console tab, and put we in the filter field
            @chrisfr1976 thanks for your trust
            do this
            git checkout main
            git fetch origin pull/8/head:test_multi-3
            git checkout test_multi-3
            and try again 1 instance and then both
            C 2 Replies Last reply
              @sdetweil Okay, nearly okay. I see the module twice on the screen. The following issues are on my Mirror:
              • SoC for both cars is 0% - main point of interest :-)
              • The pictures are the same (it is stored in the same folder with the same name. That is the reason for sure.) - not really needed
              • My Calendar Ext3 stays empty. All events are broadcasted without any error. That is something in behind. I had that before when both modules (the original and my copy if both had enabled=true set). No error in the logs or any entry that is new for me.
              Regards, Chris.
                Short update: CalendarExt3 is now okay. Maybe it needed just some more time.
                And the SoC is just missing. The remaining km-range is there. I checked it in the cars. The value is correct.
                Regards, Chris.
                  @chrisfr1976 pictures. I think that comes back on the API. let me check.
                  soc… also let me check.
                  ext3. yes, as it is getting data from the default calendar, he is trying not to flash the display too many times. some calendars can take 10 seconds to process with all the old dead entries. he doesn’t know(altho he could! hmmm)
                  you can change the Ext3 wait time if you know how long it takes roughly.
                    @chrisfr1976 ok, fixed
                    the author has accepted these fixes too
                    do this
                    git checkout main
                    git pull
                    the SoC value was not copied… don’t know where that went as I didn’t change that block. anyhow fixed
                    images, I made a sub folder by module instance… these should be correct now
                      @sdetweil Wow, thank you so much! Perfect :folded_hands: :grinning_face_with_big_eyes:
                      Regards, Chris.
                        @chrisfr1976 awesome… thanks for the feedback…
