    mmm-scenes2 and mmm-wallpaper
    5 Posts 3 Posters 1.1k Views 3 Watching
      redbeardedninja
      Alright, let’s get this out right away. I’m a total noob and am trying my best, but I’m also totally at a loss here and hoping for some help.
      Here’s what I have/what I want. Currently everything is working great, except for the last little bit. What I want this to do is have one scene “info” that shows the calendars and clock and weather, then after X amount of time, that scene goes to the “photos” scene. And then the mm just acts as a photo frame. I’m using wallpaper because it allows icloud integration. The indicators currently work on my touch screen. The only thing that I would like, is the ability to touch the screen and go back to the info scene on black only. Currently it brings up the info scene, but still has the wallpaper module in the background. Does that make sense? I’m sure I cant see the forest for the trees anymore, as I’m digging into notifications, but I can’t figure out how to make that work either. Here is a copy of my config file. Please, anyone that thinks they can help, I’m open to any and all ideas. Thanks so much for any help.
       * By Michael Teeuw https://michaelteeuw.nl
       * MIT Licensed.
       * see https://docs.magicmirror.builders/configuration/introduction.html
       * and https://docs.magicmirror.builders/modules/configuration.html
       * You can use environment variables using a `config.js.template` file instead of `config.js`
       * which will be converted to `config.js` while starting. For more information
       * see https://docs.magicmirror.builders/configuration/introduction.html#enviromnent-variables
      let config = {
      	address: "localhost",	// Address to listen on, can be:
      	port: 8080,
      	basePath: "/",			// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
      	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],	// Set [] to allow all IP addresses
      	language: "en",
      	locale: "en-US",
      	logLevel: ["INFO", "LOG", "WARN", "ERROR", "DEBUG"], // Add "DEBUG" for even more logging
      	timeFormat: 12,
      	units: "imperial",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar",
      			module: "clock",
      			classes: "PAGE ONE",
      			hiddenOnStartup: false,
                  		header: "Dinner",
                      		fetchInterval: 180000, // Refresh every 3 minutes (180000 milliseconds)
                              symbol: "calendar-check",
                              url: "https://calendar.google.com/calendar/ical/XXXXbasic.ics"
                  		module: "MMM-2Day-NOAA-Forecast",
                      		lat: XXX,
                      		lon: XXX,
                      		units: "imperial",
                      		interval: 60000 // Every 1 minute
                  		header: "Family",
      			module: "MMM-Wallpaper",
                  		position: "fullscreen_below",
                  		classes: "FINAL",
      			hiddenOnStartup: "true",
      			userPresenceAction: "hide",
                      		source: "icloud:XXXXX", // Source of the images (icloud, local)
                      		slideInterval: 60000,
                      		updateInterval: 300000,
                      		shuffle: true, // Shuffle images
                      		crossfade: true, // Crossfade duration in milliseconds
                      		opacity: 1, // Opacity of the images (0 to 1)
                      		transitionSpeed: 2000, // Speed of image transition (in milliseconds)
      				size: "cover" // Scale option for the images (cover, contain, fill, none)
      			module: "MMM-Scenes2",
      			position: "bottom_bar",
      				life: 1000 * 5,
      				defaultEnter: {
      					animation: "fadeIn",
      					duration: 1500,
      					gap: 0,
      				defaultExit: {
      					animation: "fadeOut",
      					duration: 1000,
      					gap: 0,
      				scenario: [
      						life: 1000 * 10,
      						activeIndicator: ' ',
      						inactiveIndicator: ' ',
      						enter: ["PAGE ONE"],
      						exit: [ {
      							role: "PAGE ONE",
      						enter: [ {
      							role: "FINAL",
      							duration: 2000,
      							gap: 200,
      						life: 0, // Loop end here.
      code_text
        sdetweil @redbeardedninja
        @redbeardedninja said in mmm-scenes2 and mmm-wallpaper:
        I would make this without spaces… PAGE_ONE
        because classes is a space separated list of class names… so this is
        PAGE
        and
        ONE
          redbeardedninja @sdetweil
          @sdetweil thanks for this. i made those adjustments, but it still brings up the same issue of page one showing up over the wallpaper module when i touch the monitor. I really think I’m looking for something like, when I touch the monitor (on the scenes indicator) it goes back to page one in total. doesn’t just bring up page one over the current scene.
            MMRIZE @redbeardedninja
            @redbeardedninja
            You have 3 scenes - [“info”, “unnamed”, “photos”].
            However, “info” scene has no exit order, so all modules in the previous scene will remain as they were.
            I think you need to describe enter and exit, which modules should act in the target scene.
              redbeardedninja @MMRIZE
              @MMRIZE thanks for this. that seemed to work.
