    MMM-CalendarExt3 BST Timezone issue
    26 Posts 4 Posters 7.3k Views 4 Watching
      MMRIZE @sdetweil
      Of course I can. I have already provided that manual method to my CX3 users. (https://github.com/MMRIZE/MMM-CalendarExt3/wiki/To-fix-wrong-repeated-fullday-event-displaying-(MM-2.27))
      However, the value of notification should be trustable or consistent. All other kinds of events, like In-A-Day single events, Multiday-but-not-fullday-event, and even Repeated-Not-Fullday-event, could deliver the proper time, but only Repeated-Fullday events delivered the wrong value. That is out of common sense.
      At least, it should have been guided as an intentional design. (I wasted several hours trying to guess what happened. Who could imagine the notification value was wrong?)
      PS. Ah, I forgot there was another case; imperial units on broadcasted weather information. :)
        sdetweil @MMRIZE
        @MMRIZE yes, we have had other users making updates.
          shall_ @MMRIZE
          @MMRIZE Apologies for the delayed reply, i have been busy and then couldn’t log in to the forum.
          I have tried updating, installing, and reinstalling. then adding the code into my config file but i still can’t get it to correct. I think i put the code in correctly but i have attached that so you can check. my config file isn’t throwing up any errors?
          how do i check what version of CX3 i am running? i did delete the whole folder and redo the git pull/install so i should have whatever is on github?
          			module: "MMM-CalendarExt3",
          			position: "bottom_bar",
          			title: "",
          			mode: "week", //week or month view
          			weeksInView: 5,
          			weekIndex: 0, //-1 start last week, 0 this week, 1 next week.
          			instanceId: "basicCalendar",
          			locale: 'en-GB',
          			maxEventLines: 4,
          			firstDayOfWeek: 1,
          			useWeather: true,
          			weatherLocationName: 'xxxx',
          			eventPayload: (payload) => {
          				for (let ev of payload) {
          				  if (ev.fullDayEvent) {
          					let gap = +ev.endDate - +ev.startDate
          					if (gap % (1000 * 60 * 60 * 24) === 0) {
          					  ev.startDate = new Date(+ev.startDate).setHours(0, 0, 0, 0)
          					  ev.endDate = new Date(+ev.startDate + gap).setMilliseconds(-1)
          				return payload
          			eventTransformer: (e) => {
            e.startDate = new Date(e.start?.date || e.start?.dateTime).valueOf()
            e.endDate = new Date(e.end?.date || e.end?.dateTime).valueOf()
            e.title = e.summary
            e.fullDayEvent = (e.start?.date) ? true : false
            //return e
          	if (e.title.search('Lates') > -1) e.color = 'mediumvioletred'
          	if (e.title.search('Earlies') > -1) e.color = 'yellow'
          	if (e.title.search('12 hours') > -1) e.color = 'blue'
          	if (e.title.search('12 Hours') > -1) e.color = 'blue'
          	if (e.title.search('12 hrs') > -1) e.color = 'blue'
          	if (e.title.search('Vacation') > -1) e.color = 'blue'
          	if (e.title.search('vacation') > -1) e.color = 'blue'
          	if (e.title.search('Shutdown') > -1) e.color = 'goldenrod'
          	if (e.title.search('My weekend') > -1) e.color = 'deepskyblue'
            return e
          M S 2 Replies Last reply Reply Quote 0
            MMRIZE @shall_
            @shall_
            Are you using MMM-GoogleCalendar?
              shall_ @MMRIZE
              @MMRIZE i am using the MMM-GoogleCalendar module
                shall_ @shall_
                I have managed to fix my issue, it seems the event transformer I was using (to colour mt events) may have been contradicting the fix.
                I removed the following from my event transformer which fixed the issue!
                • 3 / 3
