    Update Electron failed - MagicMirror is broken on physical screen only
    12 Posts 3 Posters 7.9k Views 3 Watching
    • P Offline
      Pade2204
      Hi.
      I have some issue with an image not updating in Electron browser but works fine in webinterface.
      I tried to update Electron in Terminal and that failed. Now I have a broken Electron browser that will not start and my Magic mirror is not showing on the screen. Webinterface still works fine.
      I have this version of Magic Mirror
      “version”: “2.12.0”,
      and further down in package.json file it says:
      “optionalDependencies”: {
      “electron”: “^6.1.7”
      Is this really the version? seems awful old though.
      Can someone help me roleback regarding the browser or can I do diagnotics of magic mirror and it will reinstall what is broken?
      Thanks.
        sdetweil @Pade2204
        @Pade2204 said in Update Electron failed - MagicMirror is broken on physical screen only:
        6.1.7
        @Pade2204 yes, quite old…
        can u tell what the message was when you tried to update? and how update?? electron
        only thing you could do it reinstall it .
        npm install electron@6.1.7
        it may not be available anymore…
        2.12
        we are at 2.27, so 15 cycles later, 4 cycles/year… almost 4 years…
        just about everything has changed…
        need a new OS, new version of node/npm, …
        so… use my backup script to get all the MM config/css/module list, see
        then copy the ~/MM_backup folder off somewhere, or use the github private repo storage approach.
        I don’t think you can upgrade MM from there (as we depend on latest stuff, which won’t run on that OS probably)
        what os level are you running… this command will tell
        lsb_release -a
        so, then the best way is flash a new sd card with the latest OS… hm… what pi is this ? 4 years… still a pi 3 probably
        and run my install script, see
        verify MM is working,
        then run the restore script from the copied back MM_backup, or same from an external disk, or from github saved
        this will get you the closest… some module may still fail due to other problems…
        were you just adding photo display?
        • P Offline
          Pade2204 @sdetweil
          I just saw a local image in module MMM-globe was not updating on the screen, but on webinterface it updated fine. So I just read that it could be the Electron browser failing. So I tried to update it. It failed, because it said that something was not compatible.
          And from now on I just tried to install Electron again - and actually 6.1.7 is avaible still, but it didnt solve my problem now.
          The Pi just shows the desktop and not MagicMirror when booted up. MagicMirror is just fine on webinterface.
            sdetweil @Pade2204
            @Pade2204 can you show the messages from where npm start is issued?
            • P Offline
              Pade2204 @sdetweil
              @sdetweil Im not that experienced in Linux, so Im not sure what you mean here.
                sdetweil @Pade2204
                @Pade2204 how do you start MagicMirror?
                if it starts at boot, do you use the MagicMirror instructions to create a service or something else?
                if you start it manually, what do you do
                all things lead to the command
                npm start
                in the MagicMirror folder
                that command starts MagicMirror and it outputs a bunch of messages when it’s running. including error messages from some modules
                • P Offline
                  Pade2204
                  Thanks.
                  I had to reinstall MagicMirror.
                    sdetweil @Pade2204
                    @Pade2204 did u reinstall the same version?
                    • P Offline
                      Pade2204 @sdetweil
                      @sdetweil I reinstalled using the guide inhere. So latest version I’m sure.
                        sdetweil @Pade2204
                        @Pade2204 i’m surprized that its running…
                        just to check
                        output of
                        grep version ~/MagicMirror/node_modules/electron/package.json
                        • C Offline
                          casper1
                          The outdated Electron version is causing the broken screen. Update to ^23.0.0, run npm install, rebuild with npm run rebuild, and restart Magic Mirror with npm start to fix it.
                            sdetweil @casper1
                            @casper1 can you explain more??
                            what did you do? update node??
