    erreur : MMM-Face-Reco-DNN
    6 Posts 2 Posters 437 Views 2 Watching
      admin
      jai un problème dans module
      MMM-Face-Reco-DNN ,
      aide moi svp
      [2024-05-05 17:48:59.807] [LOG] [MMM-Face-Reco-DNN] loading encodings + face detector…
      [2024-05-05 17:49:01.806] [ERROR] Whoops! There was an uncaught exception…
      [2024-05-05 17:49:01.818] [ERROR] PythonShellError: FileNotFoundError: [Errno 2] No such file or directory: ‘modules/MMM-Face-Reco-DNN/tools/encodings.pickle’
      at PythonShell.parseError (/home/raspberrypi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:303:21)
      at terminateIfNeeded (/home/raspberrypi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:193:32)
      at ChildProcess. (/home/raspberrypi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:185:13)
      at ChildProcess.emit (node:events:514:28)
      at ChildProcess._handle.onexit (node:internal/child_process:294:12)
      ----- Python Traceback -----
      File “/home/raspberrypi/MagicMirror/modules/MMM-Face-Reco-DNN/tools/recognition.py”, line 29, in
      data = pickle.loads(open(Arguments.get(“encodings”), “rb”).read())
      traceback: ‘Traceback (most recent call last):\n’ +
      ’ File “/home/raspberrypi/MagicMirror/modules/MMM-Face-Reco-DNN/tools/recognition.py”, line 29, in \n’ +
      ’ data = pickle.loads(open(Arguments.get(“encodings”), “rb”).read())\n’ +
      ’ ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n’ +
      “FileNotFoundError: [Errno 2] No such file or directory: ‘modules/MMM-Face-Reco-DNN/tools/encodings.pickle’\n”,
      executable: ‘python3’,
      options: null,
      script: ‘modules/MMM-Face-Reco-DNN/tools/recognition.py’,
      args: [
      ‘–cascade=modules/MMM-Face-Reco-DNN/tools/haarcascade_frontalface_default.xml’,
      ‘–encodings=modules/MMM-Face-Reco-DNN/tools/encodings.pickle’,
      ‘–rotateCamera=0’,
      ‘–method=dnn’,
      ‘–detectionMethod=hog’,
      ‘–interval=1000’,
      ‘–output=0’,
      ‘–outputmm=0’,
      ‘–extendDataset=False’,
      ‘–dataset=modules/MMM-Face-Reco-DNN/dataset/’,
      ‘–tolerance=0.6’,
      ‘–brightness=0’,
      ‘–contrast=0’,
      ‘–resolution=1920,1080’,
      ‘–processWidth=500’
      exitCode: 1
      [2024-05-05 17:49:01.820] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [2024-05-05 17:49:01.821] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
      S 1 Reply Last reply Reply Quote -1
        sdetweil @admin
        @admin said in erreur : MMM-Face-Reco-DNN:
        yes, you did not do the encoding of your user pictures
          admin @sdetweil
          @sdetweil merci pour votre réponse
          alors Jai utilise https://github.com/nischi/MMM-Face-Reco-DNN
            sdetweil @admin
            @admin yes
            see https://github.com/nischi/MMM-Face-Reco-DNN?tab=readme-ov-file#facial-recognition-embeddings
              admin @sdetweil
              mais dans dossier tools ne contient pas haarcascade_frontalface_default.xml et encodings.pickle
                sdetweil @admin
                @admin you must run a program to create those. that is the screenshot I provided from the module instructions
