    MagicMirror regions
    8 Posts 3 Posters 2.8k Views 3 Watching
    • D
      DanClarkCBET3
      I have been using Magic Mirror for years. In that time I have made some changes to the setup. One is I added regions to the index.htlm file. Until the latest update they have worked but now I get an error indicating unrecognized region for my modules. Is there a new place that I need to make these changes? Here is a copy of my changes to the index file:
      <div class="region fullscreen below"><div class="container"></div></div>
      <div class="region top bar">
        <div class="region top left"><div class="container"></div></div>
        <div class="region top center"><div class="container"></div></div>
        <div class="region top right"><div class="container"></div></div>
      </div>
      <div class="region middle"><div class="container"></div></div>
      <div class="region middle left"><div class="container"></div></div>
      <div class="region middle center"><div class="container"></div></div>
      <div class="region middle right"><div class="container"></div></div>
      </div>
      <div class="region upper third"><div class="container"></div></div>
      <div class="region lower third">
        <div class="container"><br /></div>
      </div>
      <div class="region bottom bar">
        <div class="region bottom left"><div class="container"></div></div>
        <div class="region bottom center"><div class="container"></div></div>
        <div class="region bottom right"><div class="container"></div></div>
      </div>
      <div class="region fullscreen above"><div class="container"></div></div>
        sdetweil @DanClarkCBET3
        @DanClarkCBET3 only thing you can do is edit the source at
        ~/MagicMirror/js/utils.js
                // return all available module positions
                getAvailableModulePositions () {
                        return ["top_bar", "top_left", "top_center", "top_right", "upper_third", "middle_center", "lower_third", "bottom_left", "bottom_center", "bottom_right", "bottom_bar>
        note that because you are editing our file, this will block updates
        D 1 Reply Last reply
        • D
          DanClarkCBET3 @sdetweil
          @sdetweil thanks for the help. That cleared the error but my modules are still not being displayed.
            @DanClarkCBET3 i would use the developers window to examine the dom. see if your elements have the right classes on them.
            you rechanged index.html, right?
            karsten13K 1 Reply Last reply
            • karsten13K
              karsten13 @sdetweil
              there were more changes in the corresponding PR, see https://github.com/MagicMirrorOrg/MagicMirror/pull/3445/files
                sdetweil @karsten13
                @karsten13 main should call utils to get the list. I thought it was a requested charge in the pr.
                actually the code should read index.html to get them. so users dont have to edit our code. I know it’s an edge case…
                • D
                  @sdetweil Thanks everyone. It is working perfectly now.
                  Reply Quote 1
                    @DanClarkCBET3 for the next release I have submitted a pull request to detect the regions used in index.html instead of hard coded…
