    MMPM doesn't work after reboot
    2 Posts 2 Posters 340 Views 2 Watching
      dcoistek
      Hello,
      I am very new to this and have just finished building my first Magic Mirror. I am starting to get acquainted with modules. I have no Linux background but skilled with web programming languages, and specialize in MSSQL.
      Anyhow, I have installed MMPM using the instructions from the author. It appears to run well. I can access to page, even remotely from another computer. When I turn my Pi off or reboot it however, my Magic Mirror auto starts when it comes back on, but mmpm no longer works. I cannot get it working unless I run “mmpm ui install -y” again.
      I am guessing that I either don’t have something set up right in my MM config or I need to learn how to make things auto-start when my Pi turns on.
      Thanks in advance for any help you can provide.
        sdetweil @dcoistek
        @dcoistek how did you install MagicMirror? the automated script?
        did you say yes to pm2 to autostart at boot?
        if so you can use pm2 to run another app
        see the help for the pm2 command
        pm2 --help
        in general, by convention, all linux commands are supposed to have help with
        -help of --help
        some may also pro ide a manual file
        accessible thru the man command
        man command_name
        man ls
        man pm2
        etc
        q will edit the man viewer.
        I think mmpm has a process that needs to be started to work
        pm2 start process,_name
        pm2 save
        will set it up for system at boot
        note if the process_nane is a shell script
        it needs to be named with the .sh extension, or you gave to launch the shell in the command to pm2
        pm2 start bash /c script_file_name
