    Apple calendar & server only mode
    7 Posts 2 Posters 1.4k Views 2 Watching
      dubbedMonster
      Hi all,
      I’m looking for a little guidance here. I’m having issues with displaying iCloud calendar data. When MM loads, the iCloud Calendar module states the following:
      Error in the calendar module. Check logs for more details
      I’ve tried inspecting the console for any obvious errors and I started investigating using breakpoints. It seems like the MM webpage cannot access the .ics file.
      I started with the instructions listed here. I was able to sync with iCloud using vdirsyncer and the .ics file has valid data inside that matches my phone.
      On the Docker container (mm)
      Calendar directory
      /home/node/MagicMirror/modules/calendar
      Vdirsyncer config location
      /home/node/.vdirsyncer/config
      Vdirsyncer config file
      # vdirsyncer configuration for MagicMirror.
      # Move it to ~/.vdirsyncer/config or ~/.config/vdirsyncer/config and edit it.
      # Run `vdirsyncer --help` for CLI usage.
      # Optional parameters are commented out.
      # This file doesn't document all available parameters, see
      # http://vdirsyncer.pimutils.org/ for the rest of them.
      [general]
      # A folder where vdirsyncer can store some metadata about each pair.
      status_path = "~/.vdirsyncer/status/"
      # CALDAV Sync
      [pair iCloud_to_MagicMirror]
      a = "Mirror"
      b = "iCloud"
      collections = ["Stuff"]
      # Calendars also have a color property
      metadata = ["displayname", "color"]
      [storage Mirror]
      # We need a single .ics file for use with the mirror (Attention! This is really slow on big amounts of events.)
      type = "singlefile"
      # We'll put the calendar file to a readable location for the calendar module
      path = "/home/node/MagicMirror/modules/calendars/%s.ics"
      [storage iCloud]
      type = "caldav"
      url = "https://caldav.icloud.com/"
      # Authentication credentials
      username = "email"
      password = "password"
      # We only want to sync in the direction TO the mirror, so we make iCloud readonly
      read_only = true
      # We only want to sync events
      item_types = ["VEVENT"]
      # We need to keep the number of events low, so we'll just sync the next month
      # Adjust this to your needs
      start_date = "datetime.now() - timedelta(days=1)"
      end_date = "datetime.now() + timedelta(days=30)"
      I had to make a few tweaks for Alpine and they’re listed below.
      ~/.local/bin/vdirsyncer
      is located here
      /etc/init.d
      I installed OpenRC on Alpine and used OpenRC-Run generator to convert systemd service to openrc
      vidrsyncer.timer is located here (I’m not 100% certain about this guy)
      /etc/periodic/15min
      vidrsyncer.timer file
      [Unit]
      Description=Synchronize vdirs
      [Timer]
      OnBootSec=5m
      OnUnitActiveSec=15m
      AccuracySec=5m
      [Install]
      WantedBy=timers.target
      vdirsyncer.service is located here
      /etc/init.d/
      vdirsyncer file
      vdirsyncer
      #!/sbin/openrc-run
      name=$RC_SVCNAME
      description="Synchronize calendars and contacts"
      supervisor="supervise-daemon"
      command="/usr/bin/vdirsyncer"
      command_args="sync"
      On the host machine
      docker-yaml.yml
      services:
        magicmirror:
          container_name: mm
          image: magicmirror/test:version1
          ports:
            - "8080:8080"
          volumes:
            - ../mounts/config:/opt/magic_mirror/config
            - ../mounts/modules:/opt/magic_mirror/modules
            - ../mounts/css:/opt/magic_mirror/css
          restart: unless-stopped
          command:
            - npm
            - run
            - server
      config.js location
      /home/user/mounts/config/config.js
      config.js
      /* Config Sample
       * see https://docs.magicmirror.builders/configuration/introduction.html
       * and https://docs.magicmirror.builders/modules/configuration.html
       * You can use environment variables using a `config.js.template` file instead of `config.js`
       * which will be converted to `config.js` while starting. For more information
       * see https://docs.magicmirror.builders/configuration/introduction.html#enviromnent-variables
       lat_var = 28
       long_var = 80
      let config = {
              address: "0.0.0.0",     // Address to listen on, can be:
              port: 8080,
              basePath: "/",  // The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
              ipWhitelist: ["127.0.0.1", "::ffff:192.168.1.1/120", "::1", "192.168.1.1/24"],   // Set [] to allow all IP addresses
              useHttps: false,                        // Support HTTPS or not, default "false" will use HTTP
              httpsPrivateKey: "",    // HTTPS private key path, only require when useHttps is true
              httpsCertificate: "",   // HTTPS Certificate path, only require when useHttps is true
              language: "en",
              locale: "en-US",
              logLevel: ["INFO", "LOG", "WARN", "ERROR", "DEBUG"], // Add "DEBUG" for even more logging
              timeFormat: 24,
              units: "imperial",
                              module: "alert",
                              module: "updatenotification",
                              position: "top_bar"
                              module: "clock",
                              position: "top_left"
                          module: 'calendar',
                          position: 'top_left', // This can be any of the regions. Best results in left or right regions.
                              maximumNumberOfDays: 10,
                              maximumEntries: 7,
                              calendars: [{
                                     url: "http://192.168.1.188:8080/home/node/MagicMirror/modules/calendars/Stuf.ics",
                                      symbol: 'calendar'
                              module: "compliments",
                              position: "lower_third"
                              module: "weather",
                                      weatherProvider: "openmeteo",
                                      type: "current",
                                      lat: lat_var,
                                      lon: long_var
                              module: "weather",
                              header: "Weather Forecast",
                                      type: "forecast",
                                      lat: lat_var,
                                      lon: long_var
                              module: "newsfeed",
                              position: "bottom_bar",
                                      feeds: [
                                                      title: "New York Times",
                                                      url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
                                      showSourceTitle: true,
                                      showPublishDate: true,
                                      broadcastNewsFeeds: true,
                                      broadcastNewsUpdates: true
        dubbedMonster
        Thanks for the feedback. I was able to get a sample event to show in the calendar.
        When looking at the the config.js, I was thinking that meant of the entire filesystem and not MM install directory (didn’t read that line close enough)
        I made the following changes
        On hose machine
        config.js
        url: "http:/0.0.0.0:8080/modules/calendars/1FC43665-307D-4E49-A0C5-914CA52E07EB.ics",
        On Docker
        path = "/opt/magic_mirror/modules/calendars/%s.ics"
        Ran the following code
        vdirsyncer sync --force-delete iCloud_to_MagicMirror/Stuff
        vdirsyncer sync
        Everything looks good and works! Thank you again for the help
          sdetweil @dubbedMonster
          @dubbedMonster
          url in calendar config
          no. the MagicMirror http server root is the MagicMirror folder, so anything you need to access via the http server has to be in that folder tree
          you CAN link ( ln command) something outside that tree into the tree.
          I typically advise making a data dir
          mkdir ~/MagicMirror/data
          and linking into that
          sudo ln -s real fake
          cd ~/MagicMirror/data
          sudo ln-s xxxxxx.ics Stuf.ics
          xxxxxx.is is the real absolute path and name of the file
          the in config.js the url is
          http://ocalhost:8080/data/Stuf.ics
          also you could have used pm2 to launch the syncer
            dubbedMonster
            On hose machine
            config.js
            On Docker
            vdirsyncer sync
              @dubbedMonster said in Apple calendar & server only mode:
              http:/0.0.0.0
              cool… but you should NOT use 0.0.0.0 on a url.
              0.0.0.0 means ANY network interface… it is ‘supposed’ to be reserved for LISTENERs (server apps) …
              if the server would server the file from the SAME system at the requestor, then the correct term is localhost
                dubbedMonster @sdetweil
                I don’t think I fully understand, but I’m following you. I made the change to localhost and everything still works.
                Does the same thing apply to the “address” in the config.js?
                  no… in config.js you are configuring the MM http server
                  so address:0.0.0.0 means listen for incoming requests on ALL active network interfaces (think ethernet and wifi)… without YOU having to specify their actual assigned IP addresses
                  if you WANTED ONLY requests from WIFI attached devices, then you would put in the wifi configured IP address … requests from ethernet attached devices would be ignored
                  (see the results of the ip addr command)
                  0.0.0.0 is a shortcut when u have multiple adapters and only can supply ONE address on the network listen request…
                  (else you would have to do multiple requests… the network guys like LESS work!!)
                  if you use my MMM-Config module to configure MM… I provide the address of the different networks and you can pick one (to change from default locahost for example) if you want to be network restrictive
                  localhost
                  0.0.0.0
                  etc
                    Thanks for the explanation and the help!
