    MMM-Carousel Pagination Icons
    48 Posts 8 Posters 17.5k Views 9 Watching
      sdetweil @mumblebaj
      @mumblebaj page- was never there
      mumblebajM 2 Replies Last reply Reply Quote 0
      • mumblebajM Offline
        mumblebaj Module Developer @sdetweil
        @sdetweil Yes, that is correct. I added a classname page-${i}. But the standard code was always zero based and I do not want to update that. It is tied in with MMM-pages and seems like it works with others as well.
        start() {
          this.curPage = 0;
          this.mmmPagesDetected = false;
          @sdetweil And just to note, MMM-pages is zero based. This will need to be updated as well. If I understand MMM-Carousel correct, it is also zero based.
            sdetweil @mumblebaj
            @mumblebaj one small step!
            • C Offline
              com1cedric @sdetweil
              @sdetweil Hello Sam, may I ask you one question about this topic? do you know how it would be possible to show an image stored on the Raspberry or linked from the web, instead of showing an icon from Fontawesome?
                sdetweil @com1cedric
                @com1cedric just point the url() to the file
                url('/folder_in_mm_tree/xxx.jpg/png/gif as appropriate')
                note the MM web server root is ~/MagicMirror
                so the files have to be in THAT folder tree
                you can LINK files/folders outside into the MM tree with the -->ln<-- command
                so, assume you made a
                MagicMirror/icons
                folder and in it is
                then you could use
                url('/icons/circle.png')
                or
                url('http://localhost:mm_port/icons/circle.png')  /* not this ONLY works IF the browser is on the SAME MACHINE as MM..*/
                if not you need the relative(url(‘/…’), OR have to hard code the MM machine address
                like this
                url('http://MM_IP_address:mm_port/icons/circle.png')
                if linked from the web use its complete url path
                • C Offline
                  @sdetweil said in MMM-Carousel Pagination Icons:
                  url(‘/icons/circle.png’)
                  Thank you very much Sam.
                  currently, I have the following command (which works well and shows an icon from FontAwesom) in custom.css:
                  .MMM-page-indicator div.module-content div i:nth-child(7)::after {
                  content: “\f207”;
                  font-family: FontAwesome;
                  color: #FF4433;
                  After putting an image called “olympic.png” in the “MagicMirror/icons” folder, it still does not appear if I write:
                  url(‘/icons/olympics.png’);
                  Do I habe to still use “content:” before or something else?
                  PS. sorry for asking, I am quite new in this CSS topic
                    @com1cedric i will test this out and get back
                    icons are very small images
                      @com1cedric see here, this is good info
                      https://forum.magicmirror.builders/post/125833
                      • C Offline
                        OK, I looked into it, thank you.
                        Now, I have this images from Fontawesome. It looks nice, but I would like to be able to use other image if needed.
                        For example, I would replace the “sun” with a picture “04n.png” in the “icons” forder on my raspberry.
                        I tried to change line 251 with 250 in the custom.css file
                        Now, the result is, that the sun has disappeared (correct), but just has been replaced with a gap.
                        do you maybe see a mistake in my custom.css file? the problem is maybe between lines 221 and 240. this is strange…
                        S karsten13K 2 Replies Last reply Reply Quote 0
                        • 4 / 5
