    MMM-Carousel Pagination Icons
    48 Posts 8 Posters 17.8k Views 9 Watching
      sdetweil @com1cedric
      @com1cedric can you open the developers window (ctrl-shift-i), select the console tab
      and put caro in the filter field to limit messages to the carousel module
      this info might be of help on the image selection
      https://elfsight.com/blog/svg-png-jpeg-choose-the-image-format-for-your-website/
      • karsten13K Offline
        karsten13 @com1cedric
        @com1cedric
        the /icons subfolder will not work, you have to use one of these
          sdetweil @karsten13
          @karsten13 ok, I forgot we are restrictive
          • C Offline
            com1cedric @sdetweil
            @sdetweil and @karsten13
            thank you for your inputs.
            I tried it and put the image (downloaded from flaticon.com) on the CSS file
            When I search for it in the Chromium browser (to be sure the URL is correct), it works
            but when I put this path in the custom.css files, with full or shorten path, it does not appear…
            in the console, I do not find anything suspicious (I only use mm-page and mm-page-indicator, and no carrousel).
            S mumblebajM 2 Replies Last reply Reply Quote 0
              @com1cedric again, we wont load the file path url,
              /home/… in not one of out supported folders
              it has to be MagicMirror web server based , from the MagicMirror folder as root (/)
              url('/css/house.svg')
                karsten13 @sdetweil
                I did a test with default calendar and custom.css:
                .calendar div.module-content::after {
                  content: url("/css/k13.svg");
                or
                .calendar div.module-content {
                which works (svg is visible).
                So maybe something with your css concerning the child-stuff is wrong (my css knowledge is to bad to help here)
                • mumblebajM Online
                  mumblebaj Module Developer @com1cedric
                  @com1cedric MMM-page-indicator was updated recently so you do not have to use the nth-child stuff anymore. Checkout the latest version and the readme. I have added some samples of how you can use it. You should reference the svg as either @sdetweil or @karsten13 has shown and it should work.
                  C 1 Reply Last reply Reply Quote 1
                  • C Offline
                    com1cedric @mumblebaj
                    @mumblebaj , @karsten13 and @sdetweil , thank you really for your help with this matter. I will test tomorrow and hope all this story will help other user in the future to profit from all your great job!
                    • 3 / 3
