    MMM-Carousel Pagination Icons
    48 Posts 8 Posters 24.3k Views 9 Watching
      com1cedric @sdetweil
      @sdetweil Hello Sam, may I ask you one question about this topic? do you know how it would be possible to show an image stored on the Raspberry or linked from the web, instead of showing an icon from Fontawesome?
        sdetweil @com1cedric
        @com1cedric just point the url() to the file
        url('/folder_in_mm_tree/xxx.jpg/png/gif as appropriate')
        note the MM web server root is ~/MagicMirror
        so the files have to be in THAT folder tree
        you can LINK files/folders outside into the MM tree with the -->ln<-- command
        so, assume you made a
        MagicMirror/icons
        folder and in it is
        then you could use
        url('/icons/circle.png')
        or
        url('http://localhost:mm_port/icons/circle.png')  /* not this ONLY works IF the browser is on the SAME MACHINE as MM..*/
        if not you need the relative(url(‘/…’), OR have to hard code the MM machine address
        like this
        url('http://MM_IP_address:mm_port/icons/circle.png')
        if linked from the web use its complete url path
        C 1 Reply Last reply
          @sdetweil said in MMM-Carousel Pagination Icons:
          url(‘/icons/circle.png’)
          Thank you very much Sam.
          currently, I have the following command (which works well and shows an icon from FontAwesom) in custom.css:
          .MMM-page-indicator div.module-content div i:nth-child(7)::after {
          content: “\f207”;
          font-family: FontAwesome;
          color: #FF4433;
          After putting an image called “olympic.png” in the “MagicMirror/icons” folder, it still does not appear if I write:
          url(‘/icons/olympics.png’);
          Do I habe to still use “content:” before or something else?
          PS. sorry for asking, I am quite new in this CSS topic
          S 2 Replies Last reply
            @com1cedric i will test this out and get back
            icons are very small images
              @com1cedric see here, this is good info
              https://forum.magicmirror.builders/post/125833
                OK, I looked into it, thank you.
                Now, I have this images from Fontawesome. It looks nice, but I would like to be able to use other image if needed.
                For example, I would replace the “sun” with a picture “04n.png” in the “icons” forder on my raspberry.
                I tried to change line 251 with 250 in the custom.css file
                Now, the result is, that the sun has disappeared (correct), but just has been replaced with a gap.
                do you maybe see a mistake in my custom.css file? the problem is maybe between lines 221 and 240. this is strange…
                S karsten13K 2 Replies Last reply
                  @com1cedric can you open the developers window (ctrl-shift-i), select the console tab
                  and put caro in the filter field to limit messages to the carousel module
                  this info might be of help on the image selection
                  https://elfsight.com/blog/svg-png-jpeg-choose-the-image-format-for-your-website/
                  • karsten13K
                    karsten13 @com1cedric
                    @com1cedric
                    the /icons subfolder will not work, you have to use one of these
                      sdetweil @karsten13
                      @karsten13 ok, I forgot we are restrictive
                        @sdetweil and @karsten13
                        thank you for your inputs.
                        I tried it and put the image (downloaded from flaticon.com) on the CSS file
                        When I search for it in the Chromium browser (to be sure the URL is correct), it works
                        but when I put this path in the custom.css files, with full or shorten path, it does not appear…
                        in the console, I do not find anything suspicious (I only use mm-page and mm-page-indicator, and no carrousel).
                        S mumblebajM 2 Replies Last reply
                          @com1cedric again, we wont load the file path url,
                          /home/… in not one of out supported folders
                          it has to be MagicMirror web server based , from the MagicMirror folder as root (/)
                          url('/css/house.svg')
                          karsten13K 1 Reply Last reply
                          • karsten13K
                            karsten13 @sdetweil
                            I did a test with default calendar and custom.css:
                            .calendar div.module-content::after {
                              content: url("/css/k13.svg");
                            or
                            .calendar div.module-content {
                            which works (svg is visible).
                            So maybe something with your css concerning the child-stuff is wrong (my css knowledge is to bad to help here)
                            • mumblebajM
                              mumblebaj Module Developer @com1cedric
                              @com1cedric MMM-page-indicator was updated recently so you do not have to use the nth-child stuff anymore. Checkout the latest version and the readme. I have added some samples of how you can use it. You should reference the svg as either @sdetweil or @karsten13 has shown and it should work.
                                com1cedric @mumblebaj
                                @mumblebaj , @karsten13 and @sdetweil , thank you really for your help with this matter. I will test tomorrow and hope all this story will help other user in the future to profit from all your great job!
                                Reply Quote 2
                                • 3 / 3
