    MMM-Carousel Pagination Icons
    48 Posts 8 Posters 22.9k Views 9 Watching
    • mumblebajM Offline
      @sdetweil Correct. Although, MMM-page-indicator is 0 based, same as MMM-pages, so page-0 would be page 1 etc.
        sdetweil @mumblebaj
        @mumblebaj i updated my post
          sdetweil @mumblebaj
          @mumblebaj i will say, i think for humans. 0 based is unfriendly
            @sdetweil Yeah, i would agree. Changing that logic now may have some repercussions for users already using the module.
              sdetweil @mumblebaj
              @mumblebaj page- was never there
              mumblebajM 2 Replies Last reply Reply Quote 0
                @sdetweil Yes, that is correct. I added a classname page-${i}. But the standard code was always zero based and I do not want to update that. It is tied in with MMM-pages and seems like it works with others as well.
                start() {
                  this.curPage = 0;
                  this.mmmPagesDetected = false;
                  @sdetweil And just to note, MMM-pages is zero based. This will need to be updated as well. If I understand MMM-Carousel correct, it is also zero based.
                    sdetweil @mumblebaj
                    @mumblebaj one small step!
                      com1cedric @sdetweil
                      @sdetweil Hello Sam, may I ask you one question about this topic? do you know how it would be possible to show an image stored on the Raspberry or linked from the web, instead of showing an icon from Fontawesome?
                        sdetweil @com1cedric
                        @com1cedric just point the url() to the file
                        url('/folder_in_mm_tree/xxx.jpg/png/gif as appropriate')
                        note the MM web server root is ~/MagicMirror
                        so the files have to be in THAT folder tree
                        you can LINK files/folders outside into the MM tree with the -->ln<-- command
                        so, assume you made a
                        MagicMirror/icons
                        folder and in it is
                        then you could use
                        url('/icons/circle.png')
                        or
                        url('http://localhost:mm_port/icons/circle.png')  /* not this ONLY works IF the browser is on the SAME MACHINE as MM..*/
                        if not you need the relative(url(‘/…’), OR have to hard code the MM machine address
                        like this
                        url('http://MM_IP_address:mm_port/icons/circle.png')
                        if linked from the web use its complete url path
                          @sdetweil said in MMM-Carousel Pagination Icons:
                          url(‘/icons/circle.png’)
                          Thank you very much Sam.
                          currently, I have the following command (which works well and shows an icon from FontAwesom) in custom.css:
                          .MMM-page-indicator div.module-content div i:nth-child(7)::after {
                          content: “\f207”;
                          font-family: FontAwesome;
                          color: #FF4433;
                          After putting an image called “olympic.png” in the “MagicMirror/icons” folder, it still does not appear if I write:
                          url(‘/icons/olympics.png’);
                          Do I habe to still use “content:” before or something else?
                          PS. sorry for asking, I am quite new in this CSS topic
                            @com1cedric i will test this out and get back
                            icons are very small images
                              @com1cedric see here, this is good info
                              https://forum.magicmirror.builders/post/125833
                                OK, I looked into it, thank you.
                                Now, I have this images from Fontawesome. It looks nice, but I would like to be able to use other image if needed.
                                For example, I would replace the “sun” with a picture “04n.png” in the “icons” forder on my raspberry.
                                I tried to change line 251 with 250 in the custom.css file
                                Now, the result is, that the sun has disappeared (correct), but just has been replaced with a gap.
                                do you maybe see a mistake in my custom.css file? the problem is maybe between lines 221 and 240. this is strange…
                                S karsten13K 2 Replies Last reply Reply Quote 0
                                  @com1cedric can you open the developers window (ctrl-shift-i), select the console tab
                                  and put caro in the filter field to limit messages to the carousel module
                                  this info might be of help on the image selection
                                  https://elfsight.com/blog/svg-png-jpeg-choose-the-image-format-for-your-website/
                                  • karsten13K Offline
                                    karsten13 @com1cedric
                                    @com1cedric
                                    the /icons subfolder will not work, you have to use one of these
                                      sdetweil @karsten13
                                      @karsten13 ok, I forgot we are restrictive
                                        @sdetweil and @karsten13
                                        thank you for your inputs.
                                        I tried it and put the image (downloaded from flaticon.com) on the CSS file
                                        When I search for it in the Chromium browser (to be sure the URL is correct), it works
                                        but when I put this path in the custom.css files, with full or shorten path, it does not appear…
                                        in the console, I do not find anything suspicious (I only use mm-page and mm-page-indicator, and no carrousel).
                                        S mumblebajM 2 Replies Last reply Reply Quote 0
                                          @com1cedric again, we wont load the file path url,
                                          /home/… in not one of out supported folders
                                          it has to be MagicMirror web server based , from the MagicMirror folder as root (/)
                                          url('/css/house.svg')
                                            karsten13 @sdetweil
                                            I did a test with default calendar and custom.css:
                                            .calendar div.module-content::after {
                                              content: url("/css/k13.svg");
                                            or
                                            .calendar div.module-content {
                                            which works (svg is visible).
                                            So maybe something with your css concerning the child-stuff is wrong (my css knowledge is to bad to help here)
                                            • 2 / 3
