    MMM-Carousel Pagination Icons
    48 Posts 8 Posters 24.3k Views 9 Watching
      com1cedric @sdetweil
      @sdetweil hum… I have to re-explain my question:
      fo the moment, in custom.css, the word “hockey” is used for a page using MMM-page-indicator like this:
      .MMM-page-indicator div i:nth-child(5)::after {
      content: “Hockey”;
      Let’s say, I want to replace this word “hockey”, with an image of a hockey-puck --> e.g. image “F453” on https://fontawesome.com/search?q=hockey&o=r
      Shoud I “just” write instead in custom.css:
      .MMM-page-indicator div.module-content div i:nth-child(2)::before {
          content: "\f453";
          font-family: FontAwesome;
      When I try that, the word “hockey” has disappeared, but not image of a puck is shownd. I should have missed a step…
      Can you help me? (could interest other user as well I hope). Thanks in advance!
      S mumblebajM 4 Replies Last reply
        sdetweil @com1cedric
        @com1cedric is the puck in the free section of icons?
          @com1cedric i am traveling and dont have my computer out currently, maybe after lunch time.
          can you look in the developers window console tab and see if there are any errors
            @com1cedric also, is this the 1st or second icon you are trying to change?
            C 1 Reply Last reply
              @sdetweil hello, and thank you for your time. It helped me a lot, as it is finally working now…
              I had to change “before” with “after” after the ::
              .MMM-page-indicator div.module-content div i:nth-child(2)::AFTER {
              content: “\f453”;
              So, thank you very much for your help and have a great week-end.
              • mumblebajM
                mumblebaj Module Developer @com1cedric
                @com1cedric I have submitted a PR for MMM-page-indicator which should give more flexibility per page. See example below:
                .MMM-page-indicator .fa.indicator.page-2::before {
                    content:"\f005";
                    color: orange !important;
                .MMM-page-indicator .indicator.active-page {
                   animation: pulse 1.2s ease-in-out infinite;
                If PR is accepted you should be able to target specific page indicators as shown in example above from custom.css.
                You could use this fork in the meanwhile:
                MMM-page-indicator
                  sdetweil @mumblebaj
                  @mumblebaj you know there has to be one of the icon entries for every page the user defined, right?
                  mumblebajM 1 Reply Last reply
                  • mumblebajM
                    @sdetweil Not sure if I understand you properly but the other pages would default to the standard circle. The changes I made allows you to target specific pages if you want to change the icon, add animations etc. A little easier to target individuals.
                      sdetweil @mumblebaj
                      @mumblebaj ah, what you meant to say is
                      .fa.indicator.page-n
                      where n is a number for each page found, starting at 0
                      page-0 for first page
                      page-1 for second page
                      etc
                      • mumblebajM
                        @sdetweil Correct. Although, MMM-page-indicator is 0 based, same as MMM-pages, so page-0 would be page 1 etc.
                        S 2 Replies Last reply
                          sdetweil @mumblebaj
                          @mumblebaj i updated my post
                            sdetweil @mumblebaj
                            @mumblebaj i will say, i think for humans. 0 based is unfriendly
                            • mumblebajM
                              @sdetweil Yeah, i would agree. Changing that logic now may have some repercussions for users already using the module.
                                sdetweil @mumblebaj
                                @mumblebaj page- was never there
                                mumblebajM 2 Replies Last reply
                                • mumblebajM
                                  @sdetweil Yes, that is correct. I added a classname page-${i}. But the standard code was always zero based and I do not want to update that. It is tied in with MMM-pages and seems like it works with others as well.
                                  start() {
                                    this.curPage = 0;
                                    this.mmmPagesDetected = false;
                                  • mumblebajM
                                    @sdetweil And just to note, MMM-pages is zero based. This will need to be updated as well. If I understand MMM-Carousel correct, it is also zero based.
                                      sdetweil @mumblebaj
                                      @mumblebaj one small step!
                                        @sdetweil Hello Sam, may I ask you one question about this topic? do you know how it would be possible to show an image stored on the Raspberry or linked from the web, instead of showing an icon from Fontawesome?
                                          @com1cedric just point the url() to the file
                                          url('/folder_in_mm_tree/xxx.jpg/png/gif as appropriate')
                                          note the MM web server root is ~/MagicMirror
                                          so the files have to be in THAT folder tree
                                          you can LINK files/folders outside into the MM tree with the -->ln<-- command
                                          so, assume you made a
                                          MagicMirror/icons
                                          folder and in it is
                                          then you could use
                                          url('/icons/circle.png')
                                          or
                                          url('http://localhost:mm_port/icons/circle.png')  /* not this ONLY works IF the browser is on the SAME MACHINE as MM..*/
                                          if not you need the relative(url(‘/…’), OR have to hard code the MM machine address
                                          like this
                                          url('http://MM_IP_address:mm_port/icons/circle.png')
                                          if linked from the web use its complete url path
                                            @sdetweil said in MMM-Carousel Pagination Icons:
                                            url(‘/icons/circle.png’)
                                            Thank you very much Sam.
                                            currently, I have the following command (which works well and shows an icon from FontAwesom) in custom.css:
                                            .MMM-page-indicator div.module-content div i:nth-child(7)::after {
                                            content: “\f207”;
                                            color: #FF4433;
                                            After putting an image called “olympic.png” in the “MagicMirror/icons” folder, it still does not appear if I write:
                                            url(‘/icons/olympics.png’);
                                            Do I habe to still use “content:” before or something else?
                                            PS. sorry for asking, I am quite new in this CSS topic
                                            • 2 / 3
