    MMM-Carousel Pagination Icons
    48 Posts 8 Posters 22.9k Views 9 Watching
      com1cedric @sdetweil
      @sdetweil said in MMM-Carousel Pagination Icons:
      url(‘/icons/circle.png’)
      Thank you very much Sam.
      currently, I have the following command (which works well and shows an icon from FontAwesom) in custom.css:
      .MMM-page-indicator div.module-content div i:nth-child(7)::after {
      content: “\f207”;
      font-family: FontAwesome;
      color: #FF4433;
      After putting an image called “olympic.png” in the “MagicMirror/icons” folder, it still does not appear if I write:
      url(‘/icons/olympics.png’);
      Do I habe to still use “content:” before or something else?
      PS. sorry for asking, I am quite new in this CSS topic
        sdetweil @com1cedric
        @com1cedric i will test this out and get back
        icons are very small images
          @com1cedric see here, this is good info
          https://forum.magicmirror.builders/post/125833
            OK, I looked into it, thank you.
            Now, I have this images from Fontawesome. It looks nice, but I would like to be able to use other image if needed.
            For example, I would replace the “sun” with a picture “04n.png” in the “icons” forder on my raspberry.
            I tried to change line 251 with 250 in the custom.css file
            Now, the result is, that the sun has disappeared (correct), but just has been replaced with a gap.
            do you maybe see a mistake in my custom.css file? the problem is maybe between lines 221 and 240. this is strange…
            S karsten13K 2 Replies Last reply Reply Quote 0
              @com1cedric can you open the developers window (ctrl-shift-i), select the console tab
              and put caro in the filter field to limit messages to the carousel module
              this info might be of help on the image selection
              https://elfsight.com/blog/svg-png-jpeg-choose-the-image-format-for-your-website/
              • karsten13K Offline
                karsten13 @com1cedric
                @com1cedric
                the /icons subfolder will not work, you have to use one of these
                  sdetweil @karsten13
                  @karsten13 ok, I forgot we are restrictive
                    @sdetweil and @karsten13
                    thank you for your inputs.
                    I tried it and put the image (downloaded from flaticon.com) on the CSS file
                    When I search for it in the Chromium browser (to be sure the URL is correct), it works
                    but when I put this path in the custom.css files, with full or shorten path, it does not appear…
                    in the console, I do not find anything suspicious (I only use mm-page and mm-page-indicator, and no carrousel).
                    S mumblebajM 2 Replies Last reply Reply Quote 0
                      @com1cedric again, we wont load the file path url,
                      /home/… in not one of out supported folders
                      it has to be MagicMirror web server based , from the MagicMirror folder as root (/)
                      url('/css/house.svg')
                        karsten13 @sdetweil
                        I did a test with default calendar and custom.css:
                        .calendar div.module-content::after {
                          content: url("/css/k13.svg");
                        or
                        .calendar div.module-content {
                        which works (svg is visible).
                        So maybe something with your css concerning the child-stuff is wrong (my css knowledge is to bad to help here)
                        • mumblebajM Offline
                          mumblebaj Module Developer @com1cedric
                          @com1cedric MMM-page-indicator was updated recently so you do not have to use the nth-child stuff anymore. Checkout the latest version and the readme. I have added some samples of how you can use it. You should reference the svg as either @sdetweil or @karsten13 has shown and it should work.
                            com1cedric @mumblebaj
                            @mumblebaj , @karsten13 and @sdetweil , thank you really for your help with this matter. I will test tomorrow and hope all this story will help other user in the future to profit from all your great job!
                            • 3 / 3
