    Issue with latest update
    4 Posts 2 Posters 372 Views 2 Watching
    • T Offline
      ttguru
      Hi there, this is my first time posting. I appreciate any help in advance. I updated MagicMirror, MMM-Wallpaper, and MMM-CalendarExt2 and my mirror stopped loading. :-(
      When I ran “git pull && npm run install-mm”, I got the following error:
      hint: Pulling without specifying how to reconcile divergent branches is
      hint: discouraged. You can squelch this message by running one of the following
      hint: commands sometime before your next pull:
      hint:
      hint:   git config pull.rebase false  # merge (the default strategy)
      hint:   git config pull.rebase true   # rebase
      hint:   git config pull.ff only       # fast-forward only
      hint:
      hint: You can replace "git config" with "git config --global" to set a default
      hint: preference for all repositories. You can also pass --rebase, --no-rebase,
      hint: or --ff-only on the command line to override the configured default per
      hint: invocation.
      Already up to date.
      > magicmirror@2.28.0 install-mm
      > npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
      npm ERR! code EBADENGINE
      npm ERR! engine Unsupported engine
      npm ERR! engine Not compatible with your version of node/npm: @eslint/eslintrc@3.1.0
      npm ERR! notsup Not compatible with your version of node/npm: @eslint/eslintrc@3.1.0
      npm ERR! notsup Required: {"node":"^18.18.0 || ^20.9.0 || >=21.1.0"}
      npm ERR! notsup Actual:   {"npm":"10.1.0","node":"v20.8.0"}
      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-07-25T21_39_18_726Z-debug-0.log
      Then, tried updating node using “sudo apt install node” and I end up with v20.8.0. I can’t seem to get to the required node version.
      • T Offline
        ttguru @sdetweil
        @sdetweil I was able to resolve the issue by updating my node to v20.16.0 via the following:
        https://nodejs.org/en/download/package-manager
        Then, I ran the recommended update command and it worked — I’m up and running!
        Thank you!
          sdetweil @ttguru
          @ttguru can you do
          git status
          in the MagicMirror
          so we can see what files of ours are changed
          once we resolve that,
          use my upgrade script to update, use
          force
          instead of
          apply
          see
          it will upgrade node as well
          • T Offline
            ttguru @sdetweil
            Thank you!
              sdetweil @ttguru
              @ttguru ok, you didn’t need to update node manually… the script would have done it…
              but I was more concerned with the modified MM files…(which should never happen)
