    Highlight current day in calendar
    20 Posts 2 Posters 1.0k Views 2 Watching
      rvnbrg @sdetweil
      @sdetweil i tried that multiple times
        sdetweil @rvnbrg
        @rvnbrg did you use the developer window to look at the styles?
          rvnbrg @sdetweil
          @sdetweil my raspberry 3 a+ is a bit too slow to navigate through the dev screen. That’s why I checked via my laptop’s chrome browser. But there is the background of today highlighted as expected.
          Side question: If I replace my rb 3a+ with a rb 4. Can I get everything working as it is now by just changing the sd card?
            sdetweil @rvnbrg
            @rvnbrg generally yes, moving the sd card is ok.
            now the newer bookworm built on pi4 or 5 probably won’t run on older pi3
              rvnbrg @sdetweil
              This is what I see when I check at my desktop browser.
              Would it be any different on the raspberry?
                sdetweil @rvnbrg
                @rvnbrg should not be
                that is your custom.css overriding the module css.
                unless the date is set wrong on the system.
                the styles are done in the browser.
                R 2 Replies Last reply Reply Quote 0
                  rvnbrg @sdetweil
                  @sdetweil I am currently out of ideas.
                  My time zone settings are correct, the displayed time is correct.
                  With the help of ChatGPT I tried al kind of things like adding classes to the module js file. but to no avail. I am currently on a fresh installed module and where your first tip got it working it is now not working at all. (Only works on my laptop on localhost:8080)
                    rvnbrg @sdetweil
                    @sdetweil i now reinstalled the whole mirror and still cannot get it to work on the mirror. The Dev tools on the mirror are exactly the same as on the windows laptop.
                      sdetweil @rvnbrg
                      @rvnbrg but it shows on weekdays? Or not at all anymore?
                      Is the screen contrast misadjusted?
                      You can edit the color in the dev tools top window
                      If you select that element you can enter the background color in the upper right window
                        rvnbrg @sdetweil
                        @sdetweil Sir, you did it once again. I tried editing the alpha channel from “0.2” to “0,5” and all worked out.
                        Thank you very much for all the support and your patience since the beginning of my MM journey! :)
