    Delete Fade In/Fade Out animation in the NewsFeed Module
    11 Posts 2 Posters 1.1k Views 2 Watching
    • V Offline
      victorjim @sdetweil
      @sdetweil Hello
      This is my code, I use a single screen to display 4 news.
      /* Config Sample
       * see https://docs.magicmirror.builders/configuration/introduction.html
       * and https://docs.magicmirror.builders/modules/configuration.html
       * You can use environment variables using a `config.js.template` file instead of `config.js`
       * which will be converted to `config.js` while starting. For more information
       * see https://docs.magicmirror.builders/configuration/introduction.html#enviromnent-variables
      let config = {
      	address: "localhost",	// Address to listen on, can be:
      	port: 8080,
      	basePath: "/",	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
      	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],	// Set [] to allow all IP addresses
      	useHttps: false,			// Support HTTPS or not, default "false" will use HTTP
      	httpsPrivateKey: "",	// HTTPS private key path, only require when useHttps is true
      	httpsCertificate: "",	// HTTPS Certificate path, only require when useHttps is true
      	language: "es",
      	locale: "es-ES",
      	timeFormat: 24,
      	units: "metric",
      			module: "newsfeed",
      			position: "top_bar",
      			reloadInterval: 60000,
      			animationSpeed: 5*1000,
      				feeds: [
      					title: "Portada Periodico de Aragon",
      					url: "https://www.elperiodicodearagon.com/rss/section/23500"
      				showSourceTitle: true,
      				showPublishDate: true,
      				showDescription: true,
      				broadcastNewsFeeds: true,
      				broadcastNewsUpdates: true
      			module: "newsfeed",
      				feeds: [
      					title: "Portada Periodico ABC",
      					url: "https://www.abc.es/rss/2.0/portada/"
      			module: "newsfeed",
      				feeds: [
      					title: "Portada El Mundo",
      					url: "http://estaticos.elmundo.es/elmundo/rss/espana.xml"
      			module: "newsfeed",
      				feeds: [
      					title: "Portada Libertad Digital",
      					url: "http://feeds2.feedburner.com/libertaddigital/portada"
      I hope I haven´t written this code wrong.
      The reason for putting the 4 modules separately is so that I can control the space between them a bit since, I have no experience with CSS.
      Thank you.
        sdetweil @victorjim
        @victorjim
        those two properties are for the module, not MagicMirror, so they should be inside the config:{ section, here is the doc for module parameters for MagicMirror,
        https://docs.magicmirror.builders/modules/configuration.html#example
        means 5 seconds for each news item to appear and disappear. longer animation
        you want it to be shorter or not at all
        	animationSpeed: 0,
        • V Offline
          victorjim @sdetweil
          I changed the animationSpeed: value to 0, and it still does the Fade In/Fade Out animation.
          Nothing has changed. What I would like is to remove the animation and leave the text fixed.
          Thanks.
            sdetweil @victorjim
            @victorjim said in Delete Fade In/Fade Out animation in the NewsFeed Module:
            did you MOVE the animationSpeed:0, INSIDE the config:{} section of the module definition??
            otherwise the module will not see that setting
            • V Offline
              victorjim @sdetweil
              I don’t understand well, I have changed the variable animationSpeed: 0 in the config.js file inside the /MagicMirror/config/ folder
              Like this code:
              			module: "newsfeed",
              			animationSpeed: 0,  //  In this position
              				feeds: [
                sdetweil
                @sdetweil said in Delete Fade In/Fade Out animation in the NewsFeed Module:
                so
                			module: "newsfeed",
                // move These TWO parameters
                			animationSpeed: 0,
                // INSIDE the config:{ section
                				feeds: [
                				broadcastNewsUpdates: true,
                // like this
                			        animationSpeed: 0
                module: …to config: { belong to MagicMirror, NOT the module
                config: {… } belong to the module
                • V Offline
                  victorjim @sdetweil
                  Ok
                  Now I understand.
                  The 2 variables must be set in the configuration of each news.
                  Now it is corrected and works.
                  Thank you very much.
