    Calendar shows late day events on next day but at correct time
    35 Posts 4 Posters 7.1k Views 6 Watching
    • N Offline
      natmash
      Just coming back to this after a few weeks unable to get to it.
      No luck. In addition, it still is only related to recurring events, whereas single events are set correctly. Even in a series of events the first event is fine but events after are wrong.
        sdetweil @natmash
        @natmash can you turn on debug
        add
         ,"DEBUG"
        to the logLevel list in config.js
        redirect the output of npm start to a file
        npm start >somefile.txt
          @natmash
          and maybe post one event from your cal ics file which demonstrates the issue
            MMRIZE @natmash
            @natmash @sdetweil
            It seems a bug on the default calendar module. One of my CX3 user also reported it so I looked inside.
            https://github.com/MMRIZE/MMM-CalendarExt3/discussions/146#discussioncomment-9380307
              sdetweil @MMRIZE
              @MMRIZE i expect so, I’d like to see the event from the ics to see what we can do
              • N Offline
                natmash
                BEGIN:VEVENT
                CREATED:20240904T053053Z
                DTEND;TZID=America/Chicago:20240910T211500
                DTSTAMP:20240925T005517Z
                DTSTART;TZID=America/Chicago:20240910T201500
                LAST-MODIFIED:20240925T005515Z
                RELATED-TO;RELTYPE=X-CALENDARSERVER-RECURRENCE-SET:2D48CA37-FCE5-4E16-871
                9-1F47160BDBA3
                RRULE:FREQ=WEEKLY;UNTIL=20250601T011500Z
                SEQUENCE:3
                SUMMARY:Wife Barre Class
                UID:39669340-7AFD-4685-9BD6-6CE4B715486E
                X-APPLE-CREATOR-IDENTITY:com.apple.mobilecal
                END:VEVENT
                S 2 Replies Last reply Reply Quote 1
                  sdetweil @natmash
                  @natmash thanks
                  • N Offline
                    natmash
                    Barre Class, with dates: ["2024-09-11T01:15:00.000Z","2024-09-18T01:15:00.000Z","2024-09-25T01:15:00.000Z","2024-10-02T01:15:00.000Z","2024-10-09T01:15:00.000Z","2024-10-16T01:15:00.000Z","2024-10-23T01:15:00.000Z","2024-10-30T01:15:00.000Z","2024-11-06T01:15:00.000Z","2024-11-13T01:15:00.000Z","2024-11-20T01:15:00.000Z","2024-11-27T01:15:00.000Z","2024-12-04T01:15:00.000Z","2024-12-11T01:15:00.000Z","2024-12-18T01:15:00.000Z","2024-12-25T01:15:00.000Z","2025-01-01T01:15:00.000Z","2025-01-08T01:15:00.000Z","2025-01-15T01:15:00.000Z","2025-01-22T01:15:00.000Z","2025-01-29T01:15:00.000Z","2025-02-05T01:15:00.000Z","2025-02-12T01:15:00.000Z","2025-02-19T01:15:00.000Z","2025-02-26T01:15:00.000Z","2025-03-05T01:15:00.000Z","2025-03-12T01:15:00.000Z","2025-03-19T01:15:00.000Z","2025-03-26T01:15:00.000Z","2025-04-02T01:15:00.000Z","2025-04-09T01:15:00.000Z","2025-04-16T01:15:00.000Z","2025-04-23T01:15:00.000Z","2025-04-30T01:15:00.000Z","2025-05-07T01:15:00.000Z","2025-05-14T01:15:00.000Z","2025-05-21T01:15:00.000Z","2025-05-28T01:15:00.000Z"]
                    [2024-09-28 11:26:06.920] [DEBUG] Rule has byweekday, checking for correction
                    [2024-09-28 11:26:06.920] [DEBUG] West of GMT (tzOffset: 5) and hour=20 >= 24-5, Adding 1 day to Tue Sep 10 2024 20:15:00 GMT-0500 (Central Daylight Time)
                    [2024-09-28 11:26:06.920] [DEBUG] West of GMT (tzOffset: 5) and hour=20 >= 24-5, Adding 1 day to Tue Sep 17 2024 20:15:00 GMT-0500 (Central Daylight Time)
                    [2024-09-28 11:26:06.920] [DEBUG] West of GMT (tzOffset: 5) and hour=20 >= 24-5, Adding 1 day to Tue Sep 24 2024 20:15:00 GMT-0500 (Central Daylight Time)
                    [2024-09-28 11:26:06.920] [DEBUG] West of GMT (tzOffset: 5) and hour=20 >= 24-5, Adding 1 day to Tue Oct 01 2024 20:15:00 GMT-0500 (Central Daylight Time)
                    [2024-09-28 11:26:06.920] [DEBUG] West of GMT (tzOffset: 5) and hour=20 >= 24-5, Adding 1 day to Tue Oct 08 2024 20:15:00 GMT-0500 (Central Daylight Time)
                    [2024-09-28 11:26:06.920] [DEBUG] West of GMT (tzOffset: 5) and hour=20 >= 24-5, Adding 1 day to Tue Oct 15 2024 20:15:00 GMT-0500 (Central Daylight Time)
                    [2024-09-28 11:26:06.920] [DEBUG] West of GMT (tzOffset: 5) and hour=20 >= 24-5, Adding 1 day to Tue Oct 22 2024 20:15:00 GMT-0500 (Central Daylight Time)
                    [2024-09-28 11:26:06.920] [DEBUG] West of GMT (tzOffset: 5) and hour=20 >= 24-5, Adding 1 day to Tue Oct 29 2024 20:15:00 GMT-0500 (Central Daylight Time)
                    [2024-09-28 11:26:06.920] [DEBUG] West of GMT (tzOffset: 6) and hour=19 >= 24-6, Adding 1 day to Tue Nov 05 2024 19:15:00 GMT-0600 (Central Standard Time)
                      sdetweil @natmash
                      @natmash yes… code I put in to fix another bug, in the repeating rule parser… it used to return the day prior UTC date and right time… so I adjusted it.
                      now in this one case it returns the correct UTC date…
                      if I fix this it breaks other testcases…
                      looking for another option
                        sdetweil @natmash
                        @natmash so, I think I finally have a fix for this.
                        Would you like to try it?
                        Which MagicMirror version are you using?
                        • 4 / 4
