    MMM-Face-Reco-DNN , Blank Screen error
    11 Posts 3 Posters 984 Views 3 Watching
    • O Offline
      oberk
      Hi, I am very new to Rasp Pi. Would be grateful for your help.
      I have installed MMM-Face-Reco-DNN module,
      When I run the script, I got Magic mirror screen with modules, screen for 1 sec, and then a blank screen.
      When I look at camera, camera recognizes me, and
      I got the message “Hello oberk” on mid top of a blank screen, but no other modules. And then message disappears and I end up with a blank screen, again
      Would appreciate your help.
        sdetweil @oberk
        @oberk so, its sounds like you have a short time to logoff
        and then you don’t have the classes: configured in config.js on the modules that match the person identifier
        • O Offline
          oberk @sdetweil
          You are right, thank you,
          Sorted.
          • N Offline
            N3UR0515 @oberk
            @oberk Hey, hope you are well!
            How did you get this to work correctly?
            I have successfully installed everything and my face gets detected successfully. I get the notification pop up saying I’m detected but it doesn’t switch profiles. The modules all have classes assigned too.
            Am I missing something?
            Thanks,
            Alfie
              sdetweil @N3UR0515
              @N3UR0515 show a couple modules w classes defined
              • N Offline
                N3UR0515 @sdetweil
                @sdetweil Hey, thanks for the quick reply.
                Here is my full config, it’s a fresh install with just the 2 modules installed.
                /* Config Sample
                 * see https://docs.magicmirror.builders/configuration/introduction.html
                 * and https://docs.magicmirror.builders/modules/configuration.html
                 * You can use environment variables using a `config.js.template` file instead of `config.js`
                 * which will be converted to `config.js` while starting. For more information
                 * see https://docs.magicmirror.builders/configuration/introduction.html#enviromnent-variables
                let config = {
                	address: "0.0.0.0",	// Address to listen on, can be:
                	port: 8080,
                	basePath: "/",	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                	ipWhitelist: [],	// Set [] to allow all IP addresses
                	useHttps: false,			// Support HTTPS or not, default "false" will use HTTP
                	httpsPrivateKey: "",	// HTTPS private key path, only require when useHttps is true
                	httpsCertificate: "",	// HTTPS Certificate path, only require when useHttps is true
                	language: "en",
                	locale: "en-GB",
                	timeFormat: 24,
                	units: "metric",
                			module: "alert",
                			classes: "default everyone",
                			module: "updatenotification",
                			position: "top_bar",
                			module: "clock",
                			header: "US Holidays",
                			classes: "kirsty",
                						symbol: "calendar-check",
                						url: "https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics"
                			module: "compliments",
                			position: "lower_third",
                			classes: 'kirsty'
                			module: "weather",
                				weatherProvider: "openmeteo",
                				type: "current",
                				lat: 40.776676,
                				lon: -73.971321
                			module: "weather",
                			header: "Weather Forecast",
                				type: "forecast",
                				lat: 40.776676,
                				lon: -73.971321
                			module: "newsfeed",
                			position: "bottom_bar",
                			classes: 'alfie',
                				feeds: [
                						title: "BBC News - England",
                						url: "https://feeds.bbci.co.uk/news/england/rss.xml"
                				showSourceTitle: true,
                				showPublishDate: true,
                				broadcastNewsFeeds: true,
                				broadcastNewsUpdates: true
                			module: 'MMM-ProfileSwitcher',
                				enterMessages: {
                					// I will have only one message.
                					"alfie": "You again?!?!",
                					// Kirsty has two portions
                					"kirsty": ["Oh hello.", "Hey how is it going?"]
                			module: 'MMM-Face-Reco-DNN',
                			  // Logout 15 seconds after user was not detected anymore, if they will be detected between this 15
                			  // Seconds, they delay will start again
                			  logoutDelay: 15000,
                			  // How many time the recognition starts, with a RasPi 3+ it would be good every 2 seconds
                			  checkInterval: 2000,
                			  // Module set used for when there is no face detected ie no one is in front of the camera
                			  noFaceClass: 'noface',
                			  // Module set used for when there is an unknown/unrecognised face detected
                			  unknownClass: 'unknown',
                			  // Module set used for when there is a known/recognised face detected
                			  knownClass: 'known',
                			  // Module set used for strangers and if no user is detected
                			  defaultClass: 'default',
                			  // Set of modules which should be shown for any user ie when there is any face detected
                			  everyoneClass: 'everyone',
                			  // Set of modules that are always shown - show if there is a face or no face detected
                			  alwaysClass: 'always',
                			  // xml to recognize with haarcascade
                			  cascade: 'modules/MMM-Face-Reco-DNN/model/haarcascade_frontalface_default.xml',
                			  // pre encoded pickle with the faces
                			  encodings: 'modules/MMM-Face-Reco-DNN/model/encodings.pickle',
                			  // Brightness (0-100)
                			  brightness: 0,
                			  // Contrast (0-127)
                			  contrast: 0,
                			  // Rotate camera image (-1 = no rotation, 0 = 90°, 1 = 180°, 2 = 270°)
                			  rotateCamera: -1,
                			  // method of face recognition (dnn = deep neural network, haar = haarcascade)
                			  method: 'dnn',
                			  // which face detection model to use. "hog" is less accurate but faster on CPUs. "cnn" is a more accurate
                			  // deep-learning model which is GPU/CUDA accelerated (if available). The default is "hog".
                			  detectionMethod: 'hog',
                			  // how fast in ms should the modules hide and show (face effect)
                			  animationSpeed: 0,
                			  // Path to Python to run the face recognition (null / '' means default path, with Bookworm you need to set the virutal environment like /home/youruser/python-facereco/bin/python3. You can also find out the correct path if you are activated the virtual environment and run "which python3")
                			  pythonPath: "/home/alfie/python-facereco/bin/python3",
                			  // Boolean to toggle welcomeMessage
                			  welcomeMessage: true,
                			  // Dictionary for person name mapping in welcome message
                			  // Allows for displaying name with complex character sets in welcome message
                			  // e.g. jerome => Jérôme, hideyuki => 英之, mourad => مراد
                			  usernameDisplayMapping: null,
                			  // Save some pictures from recognized people, if unknown we save it in folder "unknown"
                			  // So you can extend your dataset and retrain it afterwards for better recognitions
                			  extendDataset: false,
                			  // if extenDataset is set, you need to set the full path of the dataset
                			  dataset: 'modules/MMM-Face-Reco-DNN/dataset/',
                			  // How much distance between faces to consider it a match. Lower is more strict.
                			  tolerance: 0.6,
                			  // allow multiple concurrent user logins, 0=no, any other number is the maximum number of concurrent logins
                			  multiUser: 0,
                			  // resoltuion of the image
                			  resolution: [1920, 1080],
                			  // width of the image for processing
                			  processWidth: 500,
                			  // output image on mm
                			  outputmm: 0,
                			  // turn on extra debugging 0=no, 1=yes
                			  debug: 0,
                  sdetweil @N3UR0515
                  @N3UR0515 and what is the user name detected
                  • N Offline
                    N3UR0515 @sdetweil
                    @sdetweil The username detected is alfie.
                    Here is a log extract confirming it successfully detects me:
                    0|mm  | [2024-11-02 17:20:49.387] [INFO]  Newsfeed-Fetcher: Broadcasting 26 items.
                    0|mm  | [2024-11-02 17:20:49.390] [INFO]  updatenotification: Updater Class Loaded!
                    0|mm  | [2024-11-02 17:20:49.390] [INFO]  updatenotification: Checking PM2 using...
                    0|mm  | [2024-11-02 17:20:49.401] [INFO]  updatenotification: [PM2] You are not using pm2
                    0|mm  | [2024-11-02 17:20:49.483] [INFO]  Newsfeed-Fetcher: reloadInterval set to ttl=900000 for url https://feeds.bbci.co.uk/news/england/rss.xml
                    0|mm  | [2024-11-02 17:20:49.536] [INFO]  Newsfeed-Fetcher: Broadcasting 26 items.
                    0|mm  | [2024-11-02 17:20:49.798] [INFO]  Calendar-Fetcher: Broadcasting 13 events from https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics.
                    0|mm  | [2024-11-02 17:21:04.327] [LOG]   [MMM-Face-Reco-DNN] Users alfie logged in.
                    0|mm  | [2024-11-02 17:21:06.463] [LOG]   [MMM-Face-Reco-DNN] Users alfie logged out.
                      sdetweil @N3UR0515
                      @N3UR0515 you cant have profile switcher AND facereco. they do the same thing
                      so, only newsfeed should show for alfie
                      • N Offline
                        N3UR0515 @sdetweil
                        @sdetweil Thank you so much! Knew I’d done something wrong.
                        Not sure why I thought they had to be used together.
                        Thanks for the speedy responses👊
                          sdetweil @N3UR0515
                          @N3UR0515 you would use profileswitcher if you had something else advising which profile to use and nothing else doing that function
                          facereco is doing it all
