    MMM-Face-Reco-DNN , Blank Screen error
    11 Posts 3 Posters 659 Views 3 Watching
    • N Offline
      N3UR0515 @oberk
      @oberk Hey, hope you are well!
      How did you get this to work correctly?
      I have successfully installed everything and my face gets detected successfully. I get the notification pop up saying I’m detected but it doesn’t switch profiles. The modules all have classes assigned too.
      Am I missing something?
      Thanks,
      Alfie
        sdetweil @N3UR0515
        @N3UR0515 show a couple modules w classes defined
        • N Offline
          N3UR0515 @sdetweil
          @sdetweil Hey, thanks for the quick reply.
          Here is my full config, it’s a fresh install with just the 2 modules installed.
          /* Config Sample
           * see https://docs.magicmirror.builders/configuration/introduction.html
           * and https://docs.magicmirror.builders/modules/configuration.html
           * You can use environment variables using a `config.js.template` file instead of `config.js`
           * which will be converted to `config.js` while starting. For more information
           * see https://docs.magicmirror.builders/configuration/introduction.html#enviromnent-variables
          let config = {
          	address: "0.0.0.0",	// Address to listen on, can be:
          	port: 8080,
          	basePath: "/",	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
          	ipWhitelist: [],	// Set [] to allow all IP addresses
          	useHttps: false,			// Support HTTPS or not, default "false" will use HTTP
          	httpsPrivateKey: "",	// HTTPS private key path, only require when useHttps is true
          	httpsCertificate: "",	// HTTPS Certificate path, only require when useHttps is true
          	language: "en",
          	locale: "en-GB",
          	timeFormat: 24,
          	units: "metric",
          			module: "alert",
          			classes: "default everyone",
          			module: "updatenotification",
          			position: "top_bar",
          			module: "clock",
          			header: "US Holidays",
          			classes: "kirsty",
          						symbol: "calendar-check",
          						url: "https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics"
          			module: "compliments",
          			position: "lower_third",
          			classes: 'kirsty'
          			module: "weather",
          				weatherProvider: "openmeteo",
          				type: "current",
          				lat: 40.776676,
          				lon: -73.971321
          			module: "weather",
          			header: "Weather Forecast",
          				type: "forecast",
          				lat: 40.776676,
          				lon: -73.971321
          			module: "newsfeed",
          			position: "bottom_bar",
          			classes: 'alfie',
          				feeds: [
          						title: "BBC News - England",
          						url: "https://feeds.bbci.co.uk/news/england/rss.xml"
          				showSourceTitle: true,
          				showPublishDate: true,
          				broadcastNewsFeeds: true,
          				broadcastNewsUpdates: true
          			module: 'MMM-ProfileSwitcher',
          				enterMessages: {
          					// I will have only one message.
          					"alfie": "You again?!?!",
          					// Kirsty has two portions
          					"kirsty": ["Oh hello.", "Hey how is it going?"]
          			module: 'MMM-Face-Reco-DNN',
          			  // Logout 15 seconds after user was not detected anymore, if they will be detected between this 15
          			  // Seconds, they delay will start again
          			  logoutDelay: 15000,
          			  // How many time the recognition starts, with a RasPi 3+ it would be good every 2 seconds
          			  checkInterval: 2000,
          			  // Module set used for when there is no face detected ie no one is in front of the camera
          			  noFaceClass: 'noface',
          			  // Module set used for when there is an unknown/unrecognised face detected
          			  unknownClass: 'unknown',
          			  // Module set used for when there is a known/recognised face detected
          			  knownClass: 'known',
          			  // Module set used for strangers and if no user is detected
          			  defaultClass: 'default',
          			  // Set of modules which should be shown for any user ie when there is any face detected
          			  everyoneClass: 'everyone',
          			  // Set of modules that are always shown - show if there is a face or no face detected
          			  alwaysClass: 'always',
          			  // xml to recognize with haarcascade
          			  cascade: 'modules/MMM-Face-Reco-DNN/model/haarcascade_frontalface_default.xml',
          			  // pre encoded pickle with the faces
          			  encodings: 'modules/MMM-Face-Reco-DNN/model/encodings.pickle',
          			  // Brightness (0-100)
          			  brightness: 0,
          			  // Contrast (0-127)
          			  contrast: 0,
          			  // Rotate camera image (-1 = no rotation, 0 = 90°, 1 = 180°, 2 = 270°)
          			  rotateCamera: -1,
          			  // method of face recognition (dnn = deep neural network, haar = haarcascade)
          			  method: 'dnn',
          			  // which face detection model to use. "hog" is less accurate but faster on CPUs. "cnn" is a more accurate
          			  // deep-learning model which is GPU/CUDA accelerated (if available). The default is "hog".
          			  detectionMethod: 'hog',
          			  // how fast in ms should the modules hide and show (face effect)
          			  animationSpeed: 0,
          			  // Path to Python to run the face recognition (null / '' means default path, with Bookworm you need to set the virutal environment like /home/youruser/python-facereco/bin/python3. You can also find out the correct path if you are activated the virtual environment and run "which python3")
          			  pythonPath: "/home/alfie/python-facereco/bin/python3",
          			  // Boolean to toggle welcomeMessage
          			  welcomeMessage: true,
          			  // Dictionary for person name mapping in welcome message
          			  // Allows for displaying name with complex character sets in welcome message
          			  // e.g. jerome => Jérôme, hideyuki => 英之, mourad => مراد
          			  usernameDisplayMapping: null,
          			  // Save some pictures from recognized people, if unknown we save it in folder "unknown"
          			  // So you can extend your dataset and retrain it afterwards for better recognitions
          			  extendDataset: false,
          			  // if extenDataset is set, you need to set the full path of the dataset
          			  dataset: 'modules/MMM-Face-Reco-DNN/dataset/',
          			  // How much distance between faces to consider it a match. Lower is more strict.
          			  tolerance: 0.6,
          			  // allow multiple concurrent user logins, 0=no, any other number is the maximum number of concurrent logins
          			  multiUser: 0,
          			  // resoltuion of the image
          			  resolution: [1920, 1080],
          			  // width of the image for processing
          			  processWidth: 500,
          			  // output image on mm
          			  outputmm: 0,
          			  // turn on extra debugging 0=no, 1=yes
          			  debug: 0,
            sdetweil @N3UR0515
            @N3UR0515 and what is the user name detected
            • N Offline
              N3UR0515 @sdetweil
              @sdetweil The username detected is alfie.
              Here is a log extract confirming it successfully detects me:
              0|mm  | [2024-11-02 17:20:49.387] [INFO]  Newsfeed-Fetcher: Broadcasting 26 items.
              0|mm  | [2024-11-02 17:20:49.390] [INFO]  updatenotification: Updater Class Loaded!
              0|mm  | [2024-11-02 17:20:49.390] [INFO]  updatenotification: Checking PM2 using...
              0|mm  | [2024-11-02 17:20:49.401] [INFO]  updatenotification: [PM2] You are not using pm2
              0|mm  | [2024-11-02 17:20:49.483] [INFO]  Newsfeed-Fetcher: reloadInterval set to ttl=900000 for url https://feeds.bbci.co.uk/news/england/rss.xml
              0|mm  | [2024-11-02 17:20:49.536] [INFO]  Newsfeed-Fetcher: Broadcasting 26 items.
              0|mm  | [2024-11-02 17:20:49.798] [INFO]  Calendar-Fetcher: Broadcasting 13 events from https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics.
              0|mm  | [2024-11-02 17:21:04.327] [LOG]   [MMM-Face-Reco-DNN] Users alfie logged in.
              0|mm  | [2024-11-02 17:21:06.463] [LOG]   [MMM-Face-Reco-DNN] Users alfie logged out.
                sdetweil @N3UR0515
                @N3UR0515 you cant have profile switcher AND facereco. they do the same thing
                so, only newsfeed should show for alfie
                • N Offline
                  N3UR0515 @sdetweil
                  @sdetweil Thank you so much! Knew I’d done something wrong.
                  Not sure why I thought they had to be used together.
                  Thanks for the speedy responses👊
                    sdetweil @N3UR0515
                    @N3UR0515 you would use profileswitcher if you had something else advising which profile to use and nothing else doing that function
                    facereco is doing it all
