    MMM-Face-Reco-DNN , Blank Screen error
    11 Posts 3 Posters 998 Views 3 Watching
      sdetweil @oberk
      @oberk so, its sounds like you have a short time to logoff
      and then you don’t have the classes: configured in config.js on the modules that match the person identifier
      • O Offline
        oberk @sdetweil
        You are right, thank you,
        Sorted.
        • N Offline
          N3UR0515 @oberk
          @oberk Hey, hope you are well!
          How did you get this to work correctly?
          I have successfully installed everything and my face gets detected successfully. I get the notification pop up saying I’m detected but it doesn’t switch profiles. The modules all have classes assigned too.
          Am I missing something?
          Thanks,
          Alfie
            sdetweil @N3UR0515
            @N3UR0515 show a couple modules w classes defined
            • N Offline
              N3UR0515 @sdetweil
              @sdetweil Hey, thanks for the quick reply.
              Here is my full config, it’s a fresh install with just the 2 modules installed.
              /* Config Sample
               * see https://docs.magicmirror.builders/configuration/introduction.html
               * and https://docs.magicmirror.builders/modules/configuration.html
               * You can use environment variables using a `config.js.template` file instead of `config.js`
               * which will be converted to `config.js` while starting. For more information
               * see https://docs.magicmirror.builders/configuration/introduction.html#enviromnent-variables
              let config = {
              	address: "0.0.0.0",	// Address to listen on, can be:
              	port: 8080,
              	basePath: "/",	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
              	ipWhitelist: [],	// Set [] to allow all IP addresses
              	useHttps: false,			// Support HTTPS or not, default "false" will use HTTP
              	httpsPrivateKey: "",	// HTTPS private key path, only require when useHttps is true
              	httpsCertificate: "",	// HTTPS Certificate path, only require when useHttps is true
              	language: "en",
              	locale: "en-GB",
              	timeFormat: 24,
              	units: "metric",
              			module: "alert",
              			classes: "default everyone",
              			module: "updatenotification",
              			position: "top_bar",
              			module: "clock",
              			header: "US Holidays",
              			classes: "kirsty",
              						symbol: "calendar-check",
              						url: "https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics"
              			module: "compliments",
              			position: "lower_third",
              			classes: 'kirsty'
              			module: "weather",
              				weatherProvider: "openmeteo",
              				type: "current",
              				lat: 40.776676,
              				lon: -73.971321
              			module: "weather",
              			header: "Weather Forecast",
              				type: "forecast",
              				lat: 40.776676,
              				lon: -73.971321
              			module: "newsfeed",
              			position: "bottom_bar",
              			classes: 'alfie',
              				feeds: [
              						title: "BBC News - England",
              						url: "https://feeds.bbci.co.uk/news/england/rss.xml"
              				showSourceTitle: true,
              				showPublishDate: true,
              				broadcastNewsFeeds: true,
              				broadcastNewsUpdates: true
              			module: 'MMM-ProfileSwitcher',
              				enterMessages: {
              					// I will have only one message.
              					"alfie": "You again?!?!",
              					// Kirsty has two portions
              					"kirsty": ["Oh hello.", "Hey how is it going?"]
              			module: 'MMM-Face-Reco-DNN',
              			  // Logout 15 seconds after user was not detected anymore, if they will be detected between this 15
              			  // Seconds, they delay will start again
              			  logoutDelay: 15000,
              			  // How many time the recognition starts, with a RasPi 3+ it would be good every 2 seconds
              			  checkInterval: 2000,
              			  // Module set used for when there is no face detected ie no one is in front of the camera
              			  noFaceClass: 'noface',
              			  // Module set used for when there is an unknown/unrecognised face detected
              			  unknownClass: 'unknown',
              			  // Module set used for when there is a known/recognised face detected
              			  knownClass: 'known',
              			  // Module set used for strangers and if no user is detected
              			  defaultClass: 'default',
              			  // Set of modules which should be shown for any user ie when there is any face detected
              			  everyoneClass: 'everyone',
              			  // Set of modules that are always shown - show if there is a face or no face detected
              			  alwaysClass: 'always',
              			  // xml to recognize with haarcascade
              			  cascade: 'modules/MMM-Face-Reco-DNN/model/haarcascade_frontalface_default.xml',
              			  // pre encoded pickle with the faces
              			  encodings: 'modules/MMM-Face-Reco-DNN/model/encodings.pickle',
              			  // Brightness (0-100)
              			  brightness: 0,
              			  // Contrast (0-127)
              			  contrast: 0,
              			  // Rotate camera image (-1 = no rotation, 0 = 90°, 1 = 180°, 2 = 270°)
              			  rotateCamera: -1,
              			  // method of face recognition (dnn = deep neural network, haar = haarcascade)
              			  method: 'dnn',
              			  // which face detection model to use. "hog" is less accurate but faster on CPUs. "cnn" is a more accurate
              			  // deep-learning model which is GPU/CUDA accelerated (if available). The default is "hog".
              			  detectionMethod: 'hog',
              			  // how fast in ms should the modules hide and show (face effect)
              			  animationSpeed: 0,
              			  // Path to Python to run the face recognition (null / '' means default path, with Bookworm you need to set the virutal environment like /home/youruser/python-facereco/bin/python3. You can also find out the correct path if you are activated the virtual environment and run "which python3")
              			  pythonPath: "/home/alfie/python-facereco/bin/python3",
              			  // Boolean to toggle welcomeMessage
              			  welcomeMessage: true,
              			  // Dictionary for person name mapping in welcome message
              			  // Allows for displaying name with complex character sets in welcome message
              			  // e.g. jerome => Jérôme, hideyuki => 英之, mourad => مراد
              			  usernameDisplayMapping: null,
              			  // Save some pictures from recognized people, if unknown we save it in folder "unknown"
              			  // So you can extend your dataset and retrain it afterwards for better recognitions
              			  extendDataset: false,
              			  // if extenDataset is set, you need to set the full path of the dataset
              			  dataset: 'modules/MMM-Face-Reco-DNN/dataset/',
              			  // How much distance between faces to consider it a match. Lower is more strict.
              			  tolerance: 0.6,
              			  // allow multiple concurrent user logins, 0=no, any other number is the maximum number of concurrent logins
              			  multiUser: 0,
              			  // resoltuion of the image
              			  resolution: [1920, 1080],
              			  // width of the image for processing
              			  processWidth: 500,
              			  // output image on mm
              			  outputmm: 0,
              			  // turn on extra debugging 0=no, 1=yes
              			  debug: 0,
                sdetweil @N3UR0515
                @N3UR0515 and what is the user name detected
                • N Offline
                  N3UR0515 @sdetweil
                  @sdetweil The username detected is alfie.
                  Here is a log extract confirming it successfully detects me:
                  0|mm  | [2024-11-02 17:20:49.387] [INFO]  Newsfeed-Fetcher: Broadcasting 26 items.
                  0|mm  | [2024-11-02 17:20:49.390] [INFO]  updatenotification: Updater Class Loaded!
                  0|mm  | [2024-11-02 17:20:49.390] [INFO]  updatenotification: Checking PM2 using...
                  0|mm  | [2024-11-02 17:20:49.401] [INFO]  updatenotification: [PM2] You are not using pm2
                  0|mm  | [2024-11-02 17:20:49.483] [INFO]  Newsfeed-Fetcher: reloadInterval set to ttl=900000 for url https://feeds.bbci.co.uk/news/england/rss.xml
                  0|mm  | [2024-11-02 17:20:49.536] [INFO]  Newsfeed-Fetcher: Broadcasting 26 items.
                  0|mm  | [2024-11-02 17:20:49.798] [INFO]  Calendar-Fetcher: Broadcasting 13 events from https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics.
                  0|mm  | [2024-11-02 17:21:04.327] [LOG]   [MMM-Face-Reco-DNN] Users alfie logged in.
                  0|mm  | [2024-11-02 17:21:06.463] [LOG]   [MMM-Face-Reco-DNN] Users alfie logged out.
                    sdetweil @N3UR0515
                    @N3UR0515 you cant have profile switcher AND facereco. they do the same thing
                    so, only newsfeed should show for alfie
                    • N Offline
                      N3UR0515 @sdetweil
                      @sdetweil Thank you so much! Knew I’d done something wrong.
                      Not sure why I thought they had to be used together.
                      Thanks for the speedy responses👊
                        sdetweil @N3UR0515
                        @N3UR0515 you would use profileswitcher if you had something else advising which profile to use and nothing else doing that function
                        facereco is doing it all
