    Calendar Module Error with Many Google Calendars
    15 Posts 3 Posters 2.8k Views 3 Watching
      sdetweil @moorevineyard
      @moorevineyard you can set the fetch interval by url too
        moorevineyard
        I did some more testing and it appears that there may be some sort of rate limit with Google. I haven’t been able to find anything published, but slowing down the fetch process seems to fix the problem.
        I’m not super great with JavaScript and don’t know anything about NodeJS, but this is what I did. In the calendar.js file, starting in line 121 and then down around line 158 I changed the following:
                        this.config.calendars.forEach((calendar, index) => {  // added index
                                calendar.url = calendar.url.replace("webcal://", "http://");
                                const calendarConfig = {
                                        maximumEntries: calendar.maximumEntries,
                                        maximumNumberOfDays: calendar.maximumNumberOfDays,
                                        pastDaysCount: calendar.pastDaysCount,
                                        broadcastPastEvents: calendar.broadcastPastEvents,
                                        selfSignedCert: calendar.selfSignedCert,
                                        excludedEvents: calendar.excludedEvents,
                                        fetchInterval: calendar.fetchInterval
                                if (typeof calendar.symbolClass === "undefined" || calendar.symbolClass === null) {
                                        calendarConfig.symbolClass = "";
                                if (typeof calendar.titleClass === "undefined" || calendar.titleClass === null) {
                                        calendarConfig.titleClass = "";
                                if (typeof calendar.timeClass === "undefined" || calendar.timeClass === null) {
                                        calendarConfig.timeClass = "";
                                // we check user and password here for backwards compatibility with old configs
                                if (calendar.user && calendar.pass) {
                                        Log.warn("Deprecation warning: Please update your calendar authentication configuration.");
                                        Log.warn("https://docs.magicmirror.builders/modules/calendar.html#configuration-options");
                                        calendar.auth = {
                                                user: calendar.user,
                                                pass: calendar.pass
                                 * tell helper to start a fetcher for this calendar
                                 * fetcher till cycle
        setTimeout(() => {             // added
                                this.addCalendar(calendar.url, calendar.auth, calendarConfig);
        }, index * 5000);  // 5-second delay for each calendar
        This appears to add a 5 second delay to each of the fetches (one fetch occurs every 5 seconds during startup). I added a couple random calendars and now up to 11 seems to work without a problem.
        Is it worth adding a configuration option to introduce the delay? Is Github the best place to make these kinds of suggestions?
          @moorevineyard yes, github
          you could create a pull request with the code solution
          maybe just do it if the count is over 4 ?
          11*5 = 55 seconds, almost a minute before some calendars display. Some would not like any delay
            @moorevineyard would you be willing to test a different fix?
            due to some other problems, I added an increased timeout on the fetch function for any node helper using fetch .
            I’m interested it if fixes your timeout problem (I set timeout to 30 seconds, but can be extended with an environment variable)…
            pull request https://github.com/MagicMirrorOrg/MagicMirror/pull/3660
            git branch to see what branch you are on // remember that name (with *)
            git status to see if any changed files exist(I think yes on calendar)
            git stash if any changed files
            AND we need a newer version of node js
            node -v
            which n
            if ( which n returns nothing do , sudo npm install n -g)
            then
            sudo n 20.18.1
            to use that and not break your existing system
            in the MagicMirror folder
            git stash
            git fetch origin pull/3660/head:test_timeout
            git switch test_timeout
            npm run install-mm
            then run your system
            to go back, in the MagicMirror folder
            git checkout original branch name
            git stash pop
            sudo n 20.9.0
            npm run install-mm
              @moorevineyard new MagicMirror version released. be careful to not lose your changes til after you test
