    EVCC Dashboard MM module
    4 Posts 2 Posters 1.1k Views 2 Watching
    • C
      chrisfr1976
      Hello,
      I’m using EVCC for load PV surplus. Currently I’m using parts of the EVCC dashboard in an I-Frame. This is not as nice as it could be.
      For all who don’t know what it is: EVCC.
      Has anyone tried to create something for the MM project?
      BR Chris.
      Regards, Chris.
      • R
        rabbit83ka @chrisfr1976
        @chrisfr1976 I’m using Grafana and MMM-GrafanaChart to display the data on my mirror.
        • C
          chrisfr1976 @rabbit83ka
          @rabbit83ka Hi, this looks interesting. I‘ve used Grafana in the past but I‘m definately no expert. Can you share the part of of your config.js ? Then I can try to get this running.
          Chris.
          Regards, Chris.
          • R
            @chrisfr1976 You need to set up a Grafana Dashboard based on influx. The discussions in the evcc github (for example here) are a good starting point. Then install MMM-GrafanaChart. Config.js as described in the module documentation:
            	 		module: 'MMM-GrafanaChart',
            		 	position: 'top_left',   // This can be any of the regions.
            				version: "6", // Only add this line if you are using Grafana verison 6 or greater
            				id: "V9usrR48j", // Only Mandartory if you are using Grafana verison 6 or greater found after /d/ in the url
            				host: "solarrouter", //Mandatory. See url when displaying within grafana
            				port: 3000, // Mandatory.
            				dashboardname: "pv-ubersicht-mirror", // Mandatory.
            				orgId: 1, // Mandatory.
            				panelId: 9, // Mandatory.
            				from: "now-1d", // use any of grafanas time-range-controls
            				to: "now", //
            				width: "100%", // Optional. Default: 100%
            				height: "100%", // Optional. Default: 100%
            				scrolling: "no", // Optional. Default: no
            				refreshInterval: 9000 //Optional. Default: 900 = 1/4 hour
