    Large google calendar not loading
    9 Posts 2 Posters 1.0k Views 2 Watching
      mischag
      Amazing forum…
      Trying to get my head around how to get my wife’s google calendar to load into the calendar ext3 section.
      Now I believe that it’s struggling because of the fact that this calendar has LOTS of entries, on every day, and it’s just not loading them into the calendar file fast enough. This is the first time it’s being added, so it’s probably pulling entries from years ago??
      When I load MM, it loads fine, but the log states
      [2024-10-21 21:26:03.827] [INFO] Calendar-Fetcher: Broadcasting 1 events from http://p112-caldav.icloud.com/published/2/...UBbA.
      [2024-10-21 21:26:11.915] [INFO] Calendar-Fetcher: Broadcasting 316 events from https://calendar.google.com/calendar/ical/.../public/basic.ics.
      How long should I expect it to take for it to load the entries into the calendar module? I currently have the following in the config file…
      module: "MMM-CalendarExt3",
      		position: "bottom_bar",
      		title: "Grummitt Family",
      		waitFetch: 10000,
      		refreshInterval: 900000,
      			mode: "month",
      			instanceId: "basicCalendar",
      			locale: 'en',
      			timeFormat:"h:mm a",
      			maxEventLines: 5,
      			firstDayOfWeek: 1,
      			calendarSet: ['Google']
      		// position: "bottom_bar",
      		broadcastPastEvents: false,
      			url: "webcal://p112-caldav.icloud.com/published/2/MT...UBbA",
      			color: "green"
      			url: "https://calendar.google.com/calendar/ical/.../basic.ics",
      			color: "red"
      Any advice would be appreciated, I got this to display the wife’s calendar more than mine and I can get mine to show but not hers…
        sdetweil @mischag
        @mischag lets add debug logging and see if we can catch whats going on
        add
        ,"DEBUG"
        to the logLevel property list in config.js
        the stop MagicMirror
        if using pm2
        pm2 stop all
        then
        cd ~/MagicMirror
        npm start >somefile.txt 2>&1
        wait a couple minutes
        use keyboard ctrl-q to stop MagicMirror
        use some editor tool to examine somefile.txt
        nano somefile.txt
        it is broadcasting 316 events
        if you uncomment the position for the default cal,
        does it display the correct entries
          mischag @sdetweil
          thanks for the suggestion.
          I believe I’ve found the issue, was just struggling with speed or time or both, as waited 10mins after loading magic mirror and all entries come up now.
          I did disable pastbroadcast events to try and help as well, it does make the calendar look boring though as the past events aren’t shown…
          Need to tweak it with colours too, as my wife uses multiple different colours to show different entries, but they’re all just showing as one colour at the moment, not sure how I can do that…
            sdetweil @mischag
            @mischag large calendars are always a problem… we fetch and get EVERYTHING
            and we don’t parse it, call a lib which parses EVERYTHING
            then we wade thru it, one entry at a time
            one could create a background process that reads the cal and filters out up to last month
            and create a NEW ics file that the calendar reads…
              sdetweil @mischag
              @mischag for color/etc
              you can use the ext3 filter to examine text in the event topic and set the color to be used
              try to match her choice of color here
              the default cal only has color per url
                mischag @sdetweil
                so, I was wondering if I added customEvents information to the calendar modules that CalendarExt3 is pulling info from, would it pull that info as well?
                So far I’ve done the following but it doesn’t seem to be changing anything in the CalendarExt3 on the mirror side when loading the events.
                		broadcastPastEvents: true,
                			url: "https://calendar.google.com/.../basic.ics",
                			color: "red",
                			pastDaysCount: 7,
                			fetchInterval: 75000,
                			customEvents: [
                						{keyword: 'Birthday', symbol: 'fa-solid fa-cake-candles', color: 'Gold'},
                						{keyword: 'Piano', symbol: 'fa-solid fa-music', color: 'Purple'},
                						{keyword: 'Barbies', symbol: 'fa-regular fa-futbol', color: 'Pink'},
                						{keyword: 'Legomen', symbol: 'fa-regular fa-futbol', color: 'Yellow'},
                						{keyword: 'Bandits', symbol: 'fa-regular fa-futbol', color: 'Blue'}
                  sdetweil @mischag
                  @mischag no… those are added dynamically in the UI and NOT in the data
                  you need to move the customEvents to an Ext3 eventFilter
                  oh, one more thing
                  forum post
                  all config, or logs data should be in a code block wrapper
                  to do
                  paste text into post editor
                  blank line above and below
                  select the text you just pasted
                  hit the button </>
                  above the editor box
                  this keeps indentation and also makes a scrollable box for large content
                    mischag @sdetweil
                    thank you for this. Sorry for putting it in wrong…
                    Just wondering how you mean to put the customEvents into an Ext3 eventFilter??
                    I’ve found the code to use, but I’m not sure where I put it?
                    Do I put it in the config file? and if so, is it before the config section of the Ext3 section, or within the config brackets of the Ext3 section?
                    I have tried adding it to before teh calendarSet: line, but then my calendars don’t load…
                    Then I tried adding it to after the calendarSet: line, but still nothing, not even the calendars open then?
                    I’ve read all about how the Handling Events section in the Ext3 instructions, but not sure where to put the customEvents code or eventTransformer code into the eventFilter section?
                    Any help is much appreciated thank you!!
                      sdetweil @mischag
                      @mischag ALL config for ALL modules goes in config.js.
                      all the stuff in a module config BEFORE the config:{} section is info for the MagicMirror runtime. everything inside the config:{} section belongs to the module
                      so in the MMM-CalendarExt3 module config section
                      maybe you want a transformer as you want to change it
                         module:'MMM-CalendarExt3',
                          position: xxx ,
                           config:{
                               mode:'month',
                               eventTransformer: (event) => {
                                    if(event.title.includes('Mary')
                                         event.color='red'
                                    // always return the event
                                    return event;
