    hourly forecast openweathermap doesn't show data, MagicMirror v2.28
    10 Posts 2 Posters 1.6k Views 2 Watching
      stephanvdplas
      Hello all,
      I use the default Weather module in MM three times, one current, the other two for hourly and for daily forecasts:
      			module: "weather",
      				type: "current",
      				locationID: "2743476",
      				apiKey: "******",
      				showPrecipitationAmount: true,
      				appendLocationNameToHeader: false,
      				roundTemp: true,
      				windUnits: "beaufort",
      			module: "weather",
      			header: "komende uren",
      				type: "hourly",
      				weatherEndpoint: "/onecall",
      				lat: 52.5125,
      				lon: 6.09444,
      				apiKey: "******",
      				maxEntries: 16,
      				colored: true,
      				roundTemp: true,
      			module: "weather",
      			header: "komende dagen",
      				type: "daily",
      				apiKey: "*******",
      				maxNumberOfDays : 11,
      				colored: false,
      				roundTemp: true,
      This worked like a charme, until last week, where the hourly forecast is shown empty:
      ![Schermafbeelding 2024-10-27 135201.png](/assets/uploads/files/1730033634713-schermafbeelding-2024-10-27-135201.png)
      I see no log message in the mm logs regarding this.
      What can I do to troubleshoot?
      Regards,
      Stephan
        stephanvdplas @sdetweil
        @sdetweil said in hourly forecast openweathermap doesn't show data:
        @stephanvdplas are you on MagicMirror version 2.29?
        if not, then add
        apiVersion:"3.0",
        Thank you! This did the trick!
        I am on 2.28 (and updating is not possible at the moment), but this extra line makes it work again!
          sdetweil @stephanvdplas
          @stephanvdplas logs
          weather is done all in browser
          to see the logs do
          ctrl-shift-i
          select the console tab
          put a unique part of the module name in the filter field
          wea for example
          daily should fail too, as it needs to change to /onecall and lat/lon
          openweather dropped their older 2.5 api
          so everything has to change to new apikey and parms
            I see these messages:
            moment-with-locales.js:281  Deprecation warning: value provided is not in a recognized RFC2822 or ISO format. moment construction falls back to js Date(), which is not reliable across all browsers and versions. Non RFC2822/ISO date formats are discouraged. Please refer to http://momentjs.com/guides/#/warnings/js-date/ for more info.
            Arguments:
            [0] _isAMomentObject: true, _isUTC: false, _useUTC: false, _l: undefined, _i: Manya, _f: undefined, _strict: undefined, _locale: [object Object]
            Error
                at Function.createFromInputFallback (http://192.168.5.19:8080/vendor/node_modules/moment/min/moment-with-locales.js:318:25)
                at configFromString (http://192.168.5.19:8080/vendor/node_modules/moment/min/moment-with-locales.js:2607:19)
                at configFromInput (http://192.168.5.19:8080/vendor/node_modules/moment/min/moment-with-locales.js:3050:13)
                at prepareConfig (http://192.168.5.19:8080/vendor/node_modules/moment/min/moment-with-locales.js:3033:13)
                at createFromConfig (http://192.168.5.19:8080/vendor/node_modules/moment/min/moment-with-locales.js:3000:44)
                at createLocalOrUTC (http://192.168.5.19:8080/vendor/node_modules/moment/min/moment-with-locales.js:3094:16)
                at createLocal (http://192.168.5.19:8080/vendor/node_modules/moment/min/moment-with-locales.js:3098:16)
                at hooks (http://192.168.5.19:8080/vendor/node_modules/moment/min/moment-with-locales.js:10:29)
                at Class.getFormattedValue (http://192.168.5.19:8080/modules/MMM-JsonTable/MMM-JsonTable.js:124:23)
                at http://192.168.5.19:8080/modules/MMM-JsonTable/MMM-JsonTable.js:99:31
            warn @ moment-with-locales.js:281
            Show 1 more frame
            Show less
            ```module.js:364  Parameter mismatch in module.hide: callback is not an optional parameter!
            hide @ module.js:364
            module.js:182 newsfeed is suspended.
            2module.js:182 weather is suspended.
            module.js:182 calendar is suspended.
            module.js:182 MMM-JsonTable is suspended.
            module.js:182 MMM-iFrame is suspended.
            nstreinen.js:73 NS treinen suspend()
            weather.js:164 New weather information available.
            material/:1 [Intervention] Images loaded lazily and replaced with placeholders. Load events are deferred. See https://go.microsoft.com/fwlink/?linkid=2048113
            module.js:391  Parameter mismatch in module.show: callback is not an optional parameter!
            show @ module.js:391
            (anonymous) @ MMM-Remote-Control.js:156
            socketNotificationReceived @ MMM-Remote-Control.js:150
            (anonymous) @ module.js:231
            (anonymous) @ socketclient.js:32
            Emitter.emit @ index.mjs:136
            emitEvent @ socket.js:538
            onevent @ socket.js:525
            MMSocket.socket.onevent @ socketclient.js:26
            onpacket @ socket.js:495
            (anonymous) @ manager.js:204
            Promise.then
            (anonymous) @ websocket-constructor.browser.js:5
            ondecoded @ manager.js:203
            add @ index.js:146
            ondata @ manager.js:190
            onPacket @ socket.js:341
            onPacket @ transport.js:98
            onData @ transport.js:90
            ws.onmessage @ websocket.js:68
            module.js:189 weather is resumed.
            The daily instance of the Weather module works fine. So there must be changed something in the API of openweathermap i’m afraid that makes the hourly forecast no longer working.
              @stephanvdplas yes there may be changes required
                Ok. Can you (or any reader) confirm the hourly forecast is no longer working?
                And is there something we can do to fix this?
                At the Home Assistant website, I read something about Mode setting to 3.0:
                  @stephanvdplas the default weather module works
                          module: "weather",
                          disabled: false,
                          classes: "current",
                          label: "instance 1",
                          order: "*",
                          index: 0,
                            apiKey: // mine,
                            //locationID: "5128581", // removed
                            //location: "New York",  // removed
                            lat: /// mine,
                            lon: // mine,
                            units: "imperial",
                            tempUnits: "metric",
                            windUnits: "mph",
                            timeFormat: "12",
                            useBeaufort: true,
                            lang: "en",
                            degreeLabel: true,
                            useKmh: false,
                            showHumidity: false,
                            type: "hourly",
                            maxEntries: 10,
                            fadePoint: 0.12,
                            colored: true,
                            fade: false,
                            weatherEndpoint:"/onecall"  // added
                  I do not know about this module. it is 3 years since last update
                    units: “imperial”,
                    tempUnits: “metric”,
                    windUnits: “mph”,
                    timeFormat: “12”,
                    useBeaufort: true,
                    lang: “en”,
                    degreeLabel: true,
                    useKmh: false,
                    type: “hourly”,
                    maxEntries: 10,
                    fadePoint: 0.12,
                    colored: true,
                    fade: false,
                    weatherEndpoint:“/onecall” // added
                    Hmm, with these same settings (but with my lon/lat and api-kay) it doesn’t work.
                    Yesterday I changed my subscription to this:
                    The API is working:
                    I’ll send you a PB with my API key so you can test this yourself.
                      @stephanvdplas that is what we have been saying
                        if not, then add
                        apiVersion:"3.0",
                          if not, then add
                          apiVersion:"3.0",
