    Calendar - Past Events are a different color/shade
    3 Posts 2 Posters 566 Views 2 Watching
      roysim11
      I’m having an issue where past events show as a different color. For example, the attached image I included shows the US Holidays calendar with 2 different “greens”. It seems consistent that past events are a dulled out color of the current/future events. But I would like them all to be the same color.
      Calendars and colors are set within the default Calendars module and CalendarEXT3 is used for display.
      Thank you
      • C Offline
        chrisfr1976 @roysim11
        @roysim11 See the css in the calendar module. If this is Ext3 you’ll find this:
        .CX3 .event.passed {
          filter: brightness(0.8) grayscale(0.5);
          opacity:0.5;
        Then for example to this:
        /*  filter: brightness(0.8) grayscale(0.5);
          opacity:0.5;	*/
        Cheers,
        Chris
        Regards, Chris.
        • R roysim11 has marked this topic as solved on
          roysim11 @chrisfr1976
          @chrisfr1976 Nailed it! Thank you
