    EBADENGINE
    12 Posts 2 Posters 1.9k Views 2 Watching
      juicebox
      npm error code EBADENGINE
      npm error engine Unsupported engine
      npm error engine Not compatible with your version of node/npm: magicmirror@2.29.0
      npm error notsup Not compatible with your version of node/npm: magicmirror@2.29.0
      npm error notsup Required: {"node":">=20.9.0 <21 || 22"}
      npm error notsup Actual:   {"npm":"10.9.0","node":"v23.3.0"}
      npm error A complete log of this run can be found in: /home/xavierprince/.npm/_logs/2024-12-07T21_55_00_339Z-debug-0.log
        sdetweil @juicebox
        @juicebox yes, we do not support node 23 at this time
        The doc says to check the level needed
        You can do this
        sudo npm i n -g
        sudo n 20
        Then you can do the npm run install-mm in the MagicMirror folder
        J S 2 Replies Last reply Reply Quote 0
          juicebox @sdetweil
          sorry for the late reply but I tried that and the same error appeared
          npm error notsup Required: {“node”:“>=20.9.0 <21 || 22”}
          npm error notsup Actual: {“npm”:“10.9.0”,“node”:“v23.3.0”}
            @juicebox
            Can you close and open the terminal window
            And then do
            node -v
              juicebox @sdetweil
              @sdetweil it says
              v23.3.0
                sdetweil @juicebox
                @juicebox can you redo the
                sudo n 20
                and show me the output
                J 2 Replies Last reply Reply Quote 0
                  juicebox @sdetweil
                  @sdetweil the output
                  copying : node/20.18.1
                  installed : v20.18.1 (with npm 10.8.2)
                    sdetweil @juicebox
                    @juicebox ok
                    also do
                    which nvm
                    (should return nothing)
                    then
                    hash -r
                    returns nothing
                    then
                    node -v
                      juicebox @sdetweil
                      i got that
                      v23.3.0
                        sdetweil @juicebox
                        @juicebox ok… well, I don’t know…
                        start over
                        use my install script, it adds nodejs as required
                        see
                          juicebox @sdetweil
                          tried that now it is unable to install the dependencies
                            sdetweil @juicebox
                            @juicebox tried what?
                            you flashed a new SD card, with some full image (as required)
                            booted the new sd card
                            and then ran my script
                            show me the ~/install.log
                            you CANNOT just run the script… as it does NOT undo the bad node version
