    EBADENGINE
    12 Posts 2 Posters 1.4k Views 2 Watching
      sdetweil @juicebox
      @juicebox can you redo the
      sudo n 20
      and show me the output
        juicebox @sdetweil
        @sdetweil the output
        copying : node/20.18.1
        installed : v20.18.1 (with npm 10.8.2)
          sdetweil @juicebox
          @juicebox ok
          also do
          which nvm
          (should return nothing)
          then
          hash -r
          returns nothing
          then
          node -v
            juicebox @sdetweil
            i got that
            v23.3.0
              sdetweil @juicebox
              @juicebox ok… well, I don’t know…
              start over
              use my install script, it adds nodejs as required
              see
                juicebox @sdetweil
                tried that now it is unable to install the dependencies
                  sdetweil @juicebox
                  @juicebox tried what?
                  you flashed a new SD card, with some full image (as required)
                  booted the new sd card
                  and then ran my script
                  show me the ~/install.log
                  you CANNOT just run the script… as it does NOT undo the bad node version
