    After updating MM is not displaying
    7 Posts 2 Posters 1.0k Views 2 Watching
      sixt9stang
      Hello,
      I am pretty new to MM and used the sdetweil script to install it on a Pi 3b+. It was running great until I seen that an update was available. Of course I didn’t document how I originally installed it so went to the MM site and ran the git pull && npm run install-mm commands, which didn’t work right if I remember. I then found the sdetweil scripts again and ran the update script. That seemed to work without errors but I still got no display.
      I looked at the update log and found that Node and NPM were not new enough so I updated those and rebooted. pm2 says that MagicMirror is running but it still isn’t displaying. Any help would be great.
      This is in the error log:
      A JavaScript error occurred in the main process
      Uncaught Exception:
      Error: Cannot find module ‘undici’
      Require stack:
      • /home/pi/MagicMirror/js/app.js
      • /home/pi/MagicMirror/js/electron.js
        at Module._resolveFilename (node:internal/modules/cjs/loader:1232:15)
        at s._resolveFilename (node:electron/js2c/browser_init:2:120689)
        at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
        at Module._load (node:internal/modules/cjs/loader:1058:27)
        at c._load (node:electron/js2c/node_init:2:16955)
        at Module.require (node:internal/modules/cjs/loader:1318:19)
        at require (node:internal/modules/helpers:179:18)
        at Object. (/home/pi/MagicMirror/js/app.js:15:40)
        at Module._compile (node:internal/modules/cjs/loader:1484:14)
        at Module._extensions…js (node:internal/modules/cjs/loader:1564:10)
        at Module.load (node:internal/modules/cjs/loader:1295:32)
        at Module._load (node:internal/modules/cjs/loader:1111:12)
        at Object. (/home/pi/MagicMirror/js/electron.js:4:14)
      Thanks!
        sdetweil @sixt9stang
        @sixt9stang said in After updating MM is not displaying:
        yeh, you got the new code, but need to upgrade nodejs as well…
        when you ran my upgrade script, did you notice there are TWO different commands
        one with no parm
        one with apply
        well, BECAUSE you have alreadu upgraded the code… this is the same version you already have. I won’t do an upgrade over accidentally…
        If you are in this spot do the force upgrade
        copy/paste the command
        change the apply parm (at the end) to force
          sixt9stang @sdetweil
          @sidewall I ran the bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
          From your GitHub. Do I just download the actual script, change and then run it?
            @sixt9stang just copy paste the line, no downloading…
            if there is no parm at the end it does a check, but doesn’t DO anything…
            this is to tell you if there are things you might have forgotten about before the whack everything
            then if all looks good
            you copy paste the second one,
            it has apply on the end
            this one DOES the work…
            BUT, I won’t let you upgrade OVER your pretty upgraded system… accidentally
            so as I check the version, and you are ON the current version
            the apply run will terminate because you don’t need it
            well. SOMETIMES you do…
            so copy paste and add
            force instead of apply
            test looks like this
            doit looks like this
            bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” apply
            and FORCE looks like this
            bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” force
              @sdetweil Thanks! Back up and running. I was not reading your github correctly. I kept reading and thinking the second command was going to try pushing changes from my local install to the online repository. I am pretty new to github. Thanks again for the help!
              • S sixt9stang has marked this topic as solved on
                @sixt9stang no problem… the backup/restore scripts support saving your mm config pn githib private repo
                  @sdetweil I will start playing with that to help learn to use github.
