    MMM-Config Missing changing settings
    6 Posts 2 Posters 950 Views 2 Watching
      daportelli
      Not sure if this is the correct place to not @sdetweil around a couple of issues I have found:
      -MMM-pilehole-stats, the API is missing from the config page. After saving, the API remains in the config.js file. MMM-pilehole-stats Config page.png
      -MMM-Remote-Control, the API is missing from the config page. After saving, the API remains in the config.js file. MMM-Remote-Control.png
      • Weather_Current, the config module does not read the API key or the lon/lat setting and then removes them from the file on save. Waether_Current_Before.png Waether_Current_After.png
      David
        sdetweil @daportelli
        @daportelli but , you could edit the modulename.js (MMM-pi-hole-stats.js)
        and ADD the variable definition
        apiToken: "",
        and then restart MM and go to config and it will be there
        and then you go to MMM-Config folder and run
        ./create_form_for_module.sh MMM-pi-hole-stats
        and it will generate and save the schema with the updated fields
        and you can restore the MMM-pi-hole-stats.js
        and it will be good from then on
        same with the default weather module
          @daportelli fun times…
          for the pihole problem,
          can you email me the MMM-Config/defaults_???.js
          have to rename as .txt to email
          same userid as here at gmaill
          and the others… yes, this is the one area of frustration.
          these modules use parameters not listed in the defaults:{} section of their modulename.js
          so those fields don’t exist
          the author (or anyone) can use my tools(see the MMM-Config wiki) to create a custom form to fix these problems
          and provide it with their module files, and I will use it.
          or, someone could create it and make a PR to MMM-Config and I will ship it and use it.
            from a general perspective there are three odd use cases
            one - there is a variable in a module config in config.js but not in the module definitions
            — it will be saved and restored (your pihole apikey, but pi-hole-stats has apiKey defined)
            — the generated form for that module is lost
            two - there is no variable in config.js, or adding a new module config, and some properties are not listed in the module definition
            — they will not be presented as they were unknown
            — this is also the pi-hole-stats problem as there is a new variable called apiToken, but it is not in the defaults section
            three - there was a custom form for a module provided, and it covers all the variables used, and these will be in the form data returned, but the defaults section does not list them
            when i merged the form data w config.js values, sone are missing,
            – -so i add them to the config.js entry for that
            module instance.
            — these added entries are the default values for those properties, so no harm is none, but config.js is different
              my Primary design point was to NOT REQUIRE the module to be changed
              I rechecked the overrides, and it only allows replacing the definition of a declared variable
              and cannot be used to declare one
                daportelli @sdetweil
                @sdetweil thanks for looking into it
                  apiToken: "",
