    [ERROR] unable to write js/positions.js
    14 Posts 4 Posters 2.1k Views 4 Watching
      sdetweil @FalcoonnnnPUNCH
      @FalcoonnnnPUNCH IF you had used my install script it would have done all that for you
        @FalcoonnnnPUNCH and sudo would have caused the prior problem. as the folder would have been write protected
        • F Offline
          FalcoonnnnPUNCH @sdetweil
          @sdetweil Thank you! To fix that issue, reinstall MagicMirror without using sudo command?
            @FalcoonnnnPUNCH correct. NEVER use sudo for any MagicMirror related commands
            sudo makes everything owned by root
            where no user can modify
            just use my install/upgrade scripts. listed in alternative install section of MagicMirror doc
