    Digital Clock minutes darker
    6 Posts 2 Posters 3.5k Views 2 Watching
      alfi153
      Hello
      I would like to change the style of the standard clock. I already know how to change the font and size.
      Now I would like to change the color of the minutes.
      So the hour display should be completely white and the minutes should be grayish.
      And I would like to hide the seconds display completely.
      the command “displayseconds” in the configuration does not work
      Please help
        sdetweil @alfi153
        @alfi153
        but the displayseconds is misspelled
        displaySeconds
        MagicMirror is case sensitive
        always best to copy/paste from the doc
        https://docs.magicmirror.builders/modules/clock.html#using-the-module
        color, see the second link in my signature below to use the developers window
          sdetweil @alfi153
          @alfi153 also, sadly the clock is displayed in one html element
            @alfi153
            but make these changes to the modules/default/clock/clock.js
            add property
            		sendNotifications: false,
            		splittime:false,  // add this line
            and this code
            		if (this.config.displayType !== "analog" && this.config.showTime) {
            			if (this.config.splittime) {   // add these lines
            				let ts = timeString.split(':')
            				timeString = `<span class="clockhour">${ts[0]}</span>:<span class="clockminute">${ts[1]}</span>`
            			}   // end of addition
            			timeWrapper.innerHTML = timeString;
            then in config.js for clock
                  splittime: true,
            and in css/custom.css
            .clock .clockminute {
               color: red;
              alfi153
              Thank you 🙂
                sdetweil @alfi153
                @alfi153 i will submit something for permanent support
                I have added
                https://github.com/MagicMirrorOrg/MagicMirror/pull/3737
