    Google Tasks 'client_secret' of 'this.credentials.installed' as it is undefined.
    13 Posts 2 Posters 3.0k Views 2 Watching
    • T Offline
      torafadora
      I am struggling with Google Tasks Module, I’ve been doing it for a few ours. I am able to ping the api in terminal but not in the module itself
                  module: 'MMM-GoogleTasks',
                  header: "Google Tasks",
                      credentialsPath: "C:/Users/CLT4/MagicMirror/modules/MMM-GoogleTasks/credentials.json",
                      tokenPath: "C:/Users/CLT4/MagicMirror/modules/MMM-GoogleTasks/token.json",
                      accounts: [
                              includedLists: ["MDEwNTc1NjI1MjY1ODA3NzEwNTM6MDow"]
      [2025-02-22 17:24:52.101] [ERROR] [MMM-GoogleTasks] - Error retrieving Google Tasks: TypeError: Cannot destructure property ‘client_secret’ of ‘this.credentials.installed’ as it is undefined.
      any help would be awesome
      • T Offline
        torafadora @sdetweil
        @sdetweil I got it working with that one, why can’t it work with the original, this one is too plain
          sdetweil @torafadora
          @torafadora the .installed comes from a different app type selection on the google credentials page
          T 2 Replies Last reply Reply Quote 0
          • T Offline
            @sdetweil So what would I need to do? I have my credentials.json and token.json. I thought it would pull the secret from the credentials.json.
            • T Offline
              @sdetweil What do I need to do? I already have the token.json that was generated from the credentials.json, wouldn’t the secret come from the credentials.json?
                @torafadora change the app type, and download a new credentials.json
                look inside, its text. if it has an installed key then its the correct type
                • T Offline
                  I made a new desktop application download the credentials.json ran the authenticate.mjs to generate the token.json file. But I am getting the same error as before.
                  here is the client_secret.json-
                    "installed": {
                      "client_id": "x",
                      "project_id": "xxx",
                      "auth_uri": "https://accounts.google.com/o/oauth2/auth",
                      "token_uri": "https://oauth2.googleapis.com/token",
                      "auth_provider_x509_cert_url": "https://www.googleapis.com/oauth2/v1/certs",
                      "client_secret": "xxx",
                      "redirect_uris": ["http://localhost"]
                      "account": "me",
                      "token": {
                        "access_token": "xxx",
                        "refresh_token": "xxx",
                        "scope": "https://www.googleapis.com/auth/tasks.readonly",
                        "token_type": "Bearer",
                        "refresh_token_expires_in": 604799,
                        "expiry_date": 1740275388678
                    @torafadora which goggletasks are you using?
                    i dont find those config parms in jgauth
                    • T Offline
                      @sdetweil https://github.com/spydersoft-consulting/MMM-GoogleTasks
                      This is the project I am working from. I don’t understand what you are trying to say.
                      • T Offline
                        @sdetweil Don’t need to put this in but I have worked with the google console with another module I built from scratch for reading and automatically classifying emails and that works no problem. I also know that my credentials, token and client_secret are correct because I am able to get a json response from a URL.
                          @torafadora i was looking at
                          https://github.com/jgauth/MMM-GoogleTasks
                          • T Offline
                              @torafadora i dont know,
                                @torafadora
                                maybe change the paths to
                                ‘modules/MMM-GoogleTasks/…filename’
                                as the module is executed w MagicMirror running in the MagicMirror folder
