    Google Tasks 'client_secret' of 'this.credentials.installed' as it is undefined.
    13 Posts 2 Posters 2.4k Views 2 Watching
      sdetweil @torafadora
      @torafadora the .installed comes from a different app type selection on the google credentials page
      T 2 Replies Last reply Reply Quote 0
      • T Offline
        torafadora @sdetweil
        @sdetweil So what would I need to do? I have my credentials.json and token.json. I thought it would pull the secret from the credentials.json.
        • T Offline
          @sdetweil What do I need to do? I already have the token.json that was generated from the credentials.json, wouldn’t the secret come from the credentials.json?
            @torafadora change the app type, and download a new credentials.json
            look inside, its text. if it has an installed key then its the correct type
            • T Offline
              I made a new desktop application download the credentials.json ran the authenticate.mjs to generate the token.json file. But I am getting the same error as before.
              [ERROR] [MMM-GoogleTasks] - Error retrieving Google Tasks: TypeError: Cannot destructure property ‘client_secret’ of ‘this.credentials.installed’ as it is undefined.
              here is the client_secret.json-
                "installed": {
                  "client_id": "x",
                  "project_id": "xxx",
                  "auth_uri": "https://accounts.google.com/o/oauth2/auth",
                  "token_uri": "https://oauth2.googleapis.com/token",
                  "auth_provider_x509_cert_url": "https://www.googleapis.com/oauth2/v1/certs",
                  "client_secret": "xxx",
                  "redirect_uris": ["http://localhost"]
                  "account": "me",
                  "token": {
                    "access_token": "xxx",
                    "refresh_token": "xxx",
                    "scope": "https://www.googleapis.com/auth/tasks.readonly",
                    "token_type": "Bearer",
                    "refresh_token_expires_in": 604799,
                    "expiry_date": 1740275388678
                @torafadora which goggletasks are you using?
                i dont find those config parms in jgauth
                • T Offline
                  @sdetweil https://github.com/spydersoft-consulting/MMM-GoogleTasks
                  This is the project I am working from. I don’t understand what you are trying to say.
                  • T Offline
                    @sdetweil Don’t need to put this in but I have worked with the google console with another module I built from scratch for reading and automatically classifying emails and that works no problem. I also know that my credentials, token and client_secret are correct because I am able to get a json response from a URL.
                      @torafadora i was looking at
                      https://github.com/jgauth/MMM-GoogleTasks
                      • T Offline
                        @sdetweil I got it working with that one, why can’t it work with the original, this one is too plain
