    Question about backup script
    30 Posts 3 Posters 5.9k Views 3 Watching
      sdetweil @rkorell
      @rkorell no… you can store config settings for git (the source code repository tool MagicMirror uses and most modules use (…git clone))
      and the way to make the repository that the backup uses
        rkorell @sdetweil
        @sdetweil as far as google told me it seems, I need to install Git CLI - which is not easy available for Raspi.
        Any hint?
        Sorry!
        Ralf
        R S 2 Replies Last reply Reply Quote 0
          rkorell @rkorell
          O.K,. Google is not my friend today…
          It seems that a “.gitconfig” file will do the trick …
          Will double check.
            rkorell @rkorell
            Nope.
            Doesnt’t work.
            Have created a “.gitconfig” file with
            git config --global --edit
            Entered user, email and password - but your script asks again for “user” …
            Ralf
              sdetweil @rkorell
              @rkorell the SCRIPT does not prompt
              I use these git config parms
              if [ "$user_name." == "." ]; then
              	# prompt for users name
              	git config --local user.name $user_name
              else
              fi
              if [ "$email." == "." ]; then
              	# prompt for email address
              	git config --local user.email $email
              else
              fi
              git will prompt
                sdetweil @rkorell
                @rkorell you HAVE the git cli
                git --help
                (–local means in this folder only)
                git config --local user.name “your name”
                git config --local user.email “your email”
                see here
                https://stackoverflow.com/questions/35942754/how-can-i-save-username-and-password-in-git
                and username means github userid
                  rkorell @sdetweil
                  @sdetweil said in Question about backup script:
                  OK, where do you get this from?
                  If I have a look at your other post „local means this folder only“ let me assume that you may look at „$HOME/MagicMirror/.gitconfig“
                  Is this true?
                  Than this cannot work because my
                  created a .gitconfig in $HOME …
                  Will at least try your suggestion with git config … (THANKS for this - the stackoverflow article will be chacked as well)
                  Warmest regards,
                  Ralf
                    sdetweil @rkorell
                    @rkorell if you don’t have a global ($HOME) git config,
                    i dont presume to decide this for you.
                    so i only set it in the MM_backup folder
                      sdetweil @rkorell
                      @rkorell git will look local first and global second
                        rkorell @sdetweil
                        Your:
                        git config --local user.name “my name”
                        git config --local user.email “my email”
                        plus
                        git config --local user.password “myverylonggithubtoken”
                        does the trick…
                        The stackoverflow article is confusing to me but your suggestion is there :-)
                        Thanks a lot!
                        Warm regards,
                        Ralf
                        • 3 / 3
