    MMM-OctoMonV2
    6 Posts 2 Posters 739 Views 2 Watching
      bluearmy18
      HI I can not get this module to run.
      I have another octopus module working which is MMM-IntelligentOctopus’. So I presume all my creds work. I actually have both modules running 1 works 1 does not.
      any ideas what I am missing?
      thanks for any assistance
      module: ‘MMM-OctoMonV2’,
      position: ‘top_center’,
      header: ‘ Octopus Energy’,
      elecApiUrl: ‘https://api.octopus.energy/v1/electricity-meter-points/1XXXXXXXXX/meters/22LXXXXXXX/consumption/?group_by=day’,
      elecExpApiUrl: ‘https://api.octopus.energy/v1/electricity-meter-points/13xxxxxxx/meters/22xxxxxx/consumption/?group_by=day’,
      gasApiUrl: ‘https://api.octopus.energy/v1/gas-meter-points/16xxxxxxxx/meters/E6xxxxxxxxxx/consumption/?group_by=day’,
      api_key: ‘sk_live_xxxxxxxxxxxx’,
      displayDays: 7,
      	elecMedium: 16,
      	elecHigh: 20,
      	elecCostKWH: 0.07,
      	elecCostSC: 0.6783,
      	elecExpMedium: 5,
      	elecExpHigh: 10,
      	elecExpCostKWH: 0.15,
      	elecExpCostSC: 0,
      	gasMedium: 5,
      	gasHigh: 10,
      	gasCostKWH: 0.0492,
      	gasCostSC: 0.2986,
      	decimalPlaces: 2,
      	showUpdateTime: true,
      	updateInterval: 60000*60,
      	retryDelay: 5000,
      	animationSpeed: 2000,
      S B 2 Replies Last reply Reply Quote 0
        sdetweil @bluearmy18
        @bluearmy18 can you show the output from MagicMirror startup?
        if using pm2 then
        pm2 logs --lines=100
          bluearmy18 @bluearmy18
          @bluearmy18 @sdetweil
          hi thanks for the quick response… I ran the command but when I tried to post it I get the message… the log is to big… over 32787 characters… anything more specific I can get for you?
            @bluearmy18 you can copy/paste it into a code block
            tripple backtic (left of 1 on US keyboard)
            new line
            paste
            go to end
            new line
            tripple backtic
            warning the complete calendar url will be shown in the log
            xx it out, before posting the log info
              @bluearmy18
              i deleted your post as it had your calendar url exposed
              im gonna reject the other for the same issue
              sorry forgot to warn also
              octomon is all in browser, so we need to look at the in browser log, need keyboard and mouse
              ctrl-shift-i
              select the console tab
              and enter octo in the filter field
              ctrl-shift-i to close dev window
                thanks appreciate the help. Ill have to connect the Keyboard tomorrow, so will reply again… thanks again
