    MM 2.31.0 Calendar update problems: Only udating when one of the browsers are refreshed (F5)
    5 Posts 2 Posters 634 Views 2 Watching
    • Q
      qharley
      Hi Magic Mirror people,
      I am a new user and I am trying to set up a family calendar kiosk using MM, and so far it is working great. I have the layout tweaked, and it is displaying all the most important information. Time, Weather, and appointments.
      I have deployed it server only on a proxmox hypervisor, and set it up so that it can be visible from any browser in the home. Very handy.
      The only problem I have is that even with the fetch interval set, the calender only gets updated on all the devices, if I refresh (F5) any one of them. It does not automatically fetch the new and/or updated calendar items.
      Everything else works perfectly. The weather is updated correctly, and the MMM_Calendar_ext3 plugin works as expected.
      Here is my config.js (redacted of course)
      let config = {
          address: "0.0.0.0",
          port: 8080,
          basePath: "/",
          ipWhitelist: [],
          useHttps: false,
          httpsPrivateKey: "",
          httpsCertificate: "",
          language: "en",
          locale: "en-DE",
          logLevel: ["INFO", "LOG", "WARN", "ERROR"],
          timeFormat: 24,
          units: "metric",
          serverOnly: true,
                              module: "clock",
                                      timeFormat: 24, // or "12" for AM/PM
                                      displaySeconds: true,
                                      showDate: false,
                                      dateFormat: "dddd, MMMM Do"
                              module: "weather",
                              header: "Erlangen, DE  ",
                                      type: "current",
                                      apiKey: "",
                                      lat: "49.5906368",
                                      lon: "10.9682838" //49.5906368,10.9682838
                              module: "weather",
                                      type: "forecast",
                                      apiKey: "",
                                      lat: "49.5906368",
                                      lon: "10.9682838", //49.5906368,10.9682838
                                      showPrecipitationAmount: true,
                                      colored: "true"
                              header: "Upcoming",
                              position: "top_center",
                                      fetchInterval: 30000, // interval 30s for testing
                                      refreshInterval: 30000,
                                      coloredText: false,
                                      coloredBorder: false,
                                      coloredSymbol: true,
                                      coloredBackground: false,
                                                      name: "Public Hollidays",
                                                      symbol: "calendar-check",
                                                      color: "orange",
                                                      url: "https://calendar.google.com/calendar/ical/xxxx%40import.calendar.google.com/public/basic.ics"
                                                      color: "violet",
                                                      url: ""
                                                      color: "cyan",
                                                      url: ""
                                                      color: "red",
                                                      url: ""
                                                      color: "green",
                                                      url: ""
                              module: "MMM-CalendarExt3",
                              position: "bottom_bar",
                              title: "",
                                      mode: "week",
                                      useMarquee: true,
                                      skipPassedEventToday: true,
                                      weekIndex: 0,
                                      weeksInView: 3,
                                      instanceId: "basicCalendar",
                                      locale: 'en-DE',
                                      maxEventLines: 4,
                                      firstDayOfWeek: 1,
                                      calendarSet: ['Public Hollidays', 'Q', 'J', 'I', 'Family'],
      • Q
        qharley @sdetweil
        @sdetweil Thanks for the info.
        I have no idea why this worked, but after clearing the journals, the thing started working as expected. I changed the fetch frequency back to once every 10 minutes, and it seems happy for now.
        Will do some more testing and will let you know
          sdetweil @qharley
          @qharley can you show the output of npm start
          if using pm2 then
          pm2 logs --lines=150
          warning the full calendar url will be in the logs, please edit out
          before posting
          no manual page refresh please
          you might want to clear the logs and restart
          pm2 flush
          pm2 restart MagicMirror
          S Q 2 Replies Last reply Reply Quote 0
            @qharley also, if you allow the default calendar to display, does it update? i see position is top center.
            every 30 seconds is pretty rough, and the provider might reject that
              @qharley
              because its in a proxmox container you will probable have to kill the
              npm run server
              task and start it manually
              the scripted lxc container does not set any saving of stdout or stderr
              you will have to install sudo and add that user to the sudoers file to be able to do sudo kill
              • Q
                qharley @sdetweil
