    Electron Browser Crashing?
    8 Posts 2 Posters 2.2k Views 2 Watching
      dathbe
      I’m having a recent (last couple weeks) issue where I’ll walk past my mirror to find that it has partially crashed and is only showing a black screen with a cursor. It does not crash all the way to the home screen (which would have a menu bar at the top), and MagicMirror itself does not seem to be crashing because my logs (pm2 log mm) are still showing regular module updates without any errors or warnings.
      Anyone have any idea what’s going on?
      My setup:
      Raspi 4B
      Raspbian Buster
      MM installed using @sdetweil 's install script
        sdetweil @dathbe
        @dathbe typically the black screen is an out of memory condition or a fault in some core drawing code
        Very hard to find.
        Adding. MMM-Logging or MMM-LogExt
        To capture browser logs may help, maybe not
        As you are buster, this presents more issues as everything has changed significantly since then
        Os, node, electron, MagicMirror and many modules
          dathbe @sdetweil
          @sdetweil Thanks. I’ll see if that turns anything up.
            dathbe @sdetweil
            I woke up to a crashed browser, and this is the only error message in my log:
            [304749:0625/052044.668867:ERROR:network_service_instance_impl.cc(612)] Network service crashed, restarting service.
            Does this mean anything to anyone?
            I found this other thread, which seems to be a related though not the same issue:
            https://forum.magicmirror.builders/topic/19130/error-network_service_instance_impl-cc-600/7
            I also found this, with no real solution I see other than maybe it’s temperature related? My Pi is reporting 55 deg C - 63 deg C. I thought that was within normal operating, but maybe not?
            https://forum.magicmirror.builders/topic/16421/every-few-hours-i-get-error-network_service_instance_impl-cc-916-network-service-crashed-restarting-service/34?page=4
              sdetweil @dathbe
              @dathbe said in Electron Browser Crashing?:
              was another https://issues.chromium.org/issues/41487253
              export CHROMIUM_FLAGS=–password-store=basic
              there is also a config parm for flags , before the modules: array
              electronSwitches:{
                  "password-store":"basic"  /* needs quotes for the - */
                dathbe @sdetweil
                I added the following to my config.js file:
                units: "imperial",
                electronSwitches: {
                    "password-store": "basic" /* needs quotes for the - */
                And yet I again got another black screen (with cursor). This time, my error logs are entirely empty except for a couple fetch errors that tend to happen now and again.
                  sdetweil @dathbe
                  @dathbe as I said, hard to catch
                    dathbe @sdetweil
                    I’ve been rotating through disabling modules on my Mirror. I have currently disabled MMM-Pinfo, and have not noticed a crash recently. Noting it here for posterity. I’ll create an issue on Github if I get more confidence that it’s that module.
