    MMM-Universal-Pir and cec-client
    5 Posts 3 Posters 893 Views 3 Watching
    • M
      MM_Noob
      Hi all…
      Is anyone using MMM-Universal-Pir with cec-client to control the screen power status ?
      I’m using a Samsung LED TV that doesnt cleanly handle wlr-randr calls, but CEC works flawlessly…
      I can use cec-client on the cmdline to standby and powerup the screen with no issues…
      When I put those cmds into MMM-Universal-Pir it doesn’t call them… So my config looks something like::
        onCommand: "echo 'on 0' | cec-client -s -d 1",
        offCommand: "echo 'standby 0' | cec-client -s -d 1",
      I see the countdown timer reach 0 but the screen doesnt power off…
      Anyone got this working ??
      S karsten13K 2 Replies Last reply
        sdetweil @MM_Noob
        @MM_Noob I don’t know for his module, but my MMM-SleepWake can do cec, using debug
        are there any messages in the log where npm start is done?
        if using pm2 to launch, see the output of
        pm2 logs --lines=xxx
        xxx is the number of most recent log lines, default 15
        sleep
        [2025-07-05 10:14:22.267] [LOG]   motion detected from external source
        [2025-07-05 10:14:22.268] [LOG]   !e: motionend
        [2025-07-05 10:14:22.268] [LOG]   idle timer started for 1 minutes
        [2025-07-05 10:15:16.088] [LOG]   sleep-wake helper in socket notification=start_sleep
        [2025-07-05 10:15:16.089] [LOG]   processing start sleep
        [2025-07-05 10:15:16.089] [LOG]   using CEC approach ()='echo standby 0 | cec-client -s'
        [2025-07-05 10:15:22.270] [LOG]   sleep-wake helper in socket notification=start_sleep
        [2025-07-05 10:15:22.271] [LOG]   processing start sleep
        [2025-07-05 10:15:22.271] [LOG]   start sleep, already sleeping
        wake up
        [2025-07-05 10:15:42.503] [LOG]   motion detected from external source
        [2025-07-05 10:15:42.504] [LOG]   !s: motionstart
        [2025-07-05 10:15:42.505] [LOG]   sleep-wake helper in socket notification=end_sleep
        [2025-07-05 10:15:42.506] [LOG]   waking up
        [2025-07-05 10:15:42.506] [LOG]   waking up using CEC approach='echo on 0 | cec-client -s'
        • karsten13K
          karsten13 @MM_Noob
          @MM_Noob
          I have no hardware to reproduce but maybe this helps for debugging:
          Go to an empty dir and execute npm init -y, then write a file index.js with content:
          const { exec } = require('node:child_process');
          const onCommand = "echo 'on 0' | cec-client -s -d 1 > test.log";
          console.dir(onCommand);
          exec(onCommand, (error, stdout, stderr) => {
            if (error) {
              console.error(`exec error: ${error}`);
              return;
            console.log(`stdout: ${stdout}`);
            console.error(`stderr: ${stderr}`);
          Now run node index.js and look into presented output and into the file test.log. You can play with the content of onCommand, maybe you find what’s going wrong.
          • M
            MM_Noob
            OK - post the update to include the cec-utils in the build I can confirm it now works…
            I escaped the special chars initially in the cec-client call- but it works without them being escaped also
            I guess this update will be rolled into the latest release at some point ?
            Many thanks
            karsten13K 1 Reply Last reply
            • karsten13K
              karsten13 @MM_Noob
              @MM_Noob
              @MM_Noob said in MMM-Universal-Pir and cec-client:
              don’t understand, are you talking about this?
              which update, which release?
