    Cant exit auto running MM
    3 Posts 2 Posters 1.1k Views 2 Watching
    • _
      _V_
      Hey again guys
      So I installed MM via Sams installer and because I didnt understand how to start it from “desktop” mode, I activated autostart.
      But now I can only end it via CTRL + Q, ending in it restarts immediately ^^
      The normal Pi button does nothing, I can reach the desk through windows style CTRL ALT DEL but every click I make results in MM goes back fullscreen. I could use the “Run” menu, but thats not the same like the command prompt is it?
      Sorry for the nooby question, help is appreciated.
      Regards from Germany
        sdetweil @_V_
        @_V_ pm2’s JOB is to start the app AND KEEP IT RUNNING, so if it fails (you do a ctrl-q) pm2 restarts it
        pm2 has lots of command options
        in linux by convention commands don’t return any message when successful (as they were built when tty was VERY SLOW)
        also, each command has help
        pm2 --help
        and a manual page
        man pm2
        SO, to stop MM with pm2, minimize MM, ctrl-m, (or alt-spacebar, n) open a terminal window, ctrl-alt-v, and type
        pm2 status
        then
        pm2 stop xx
        where xx is the name or the number of the row with the app on it…
        one can create MULTIPLE managed apps with the SAME name, so sometimes the number matters
        Reply Quote 1
        • _
          _V_
          I know that its the job of it to keep it running, Ive read that
