    Module updates question
    6 Posts 2 Posters 1.1k Views 2 Watching
      RonR
      I have recently done 3 module updates and all of them threw an error when I did the ‘git pull’
      Below is the output of the last upgrade. It indicates I have made changes to files I have never touched intentionally. I have done the “git stash” to clear the error and completed the upgrades. I went looking for a file that may give me an idea of what was changed. With my limited knowledge that led nowhere.
      This is on MM 2.33 running in docker. It has happened on both my laptop and the RPI 5.
      I appreciate any info someone has.
      Thanks, Ron R
      node@8ef60e7ba2e0:/opt/magic_mirror/modules/MMM-Config$ git pull
      From https://github.com/sdetweil/MMM-Config
         c1b0dcb..65eb6cd  main       -> origin/main
      Updating c1b0dcb..65eb6cd
      error: Your local changes to the following files would be overwritten by merge:
      	module_installer/install_module.cmd
      Please commit your changes or stash them before you merge.
      Aborting
      node@8ef60e7ba2e0:/opt/magic_mirror/modules/MMM-Config$ git stash
      Saved working directory and index state WIP on main: c1b0dcb fix linux builder for linked module folder
      Fast-forward
       module_installer/install_module.cmd | 48 +++++++++++++++------
       module_installer/install_module.sh  | 86 ++++++++++++++++++++++---------------
       2 files changed, 86 insertions(+), 48 deletions(-)
      node@8ef60e7ba2e0:/opt/magic_mirror/modules/MMM-Config$ exit
      exit
        sdetweil @RonR
        @RonR hmm. I updated those to fix the install for missing dependencies. Don’t know why you have them out of sequence
        Do
        cd modules/MMM-Config
        And
        git checkout xxxx
        For each of the files
        Then
        git pull
        To resync the MMM-Config module
          RonR
          Ran git checkout on the one file listed in the error, “module_installer/install_module.cmd”. Results below. Then ran git pull again and it said everything was up to date.
          Thanks for your help.
          ron@ron-16-U:~/magicmirror/mounts/modules/MMM-Config/module_installer$ git checkout install_module.cmd
          Updated 1 path from the index
          • R RonR has marked this topic as solved on
            sdetweil @RonR
            @RonR weird.
              RonR
              My whole life in computers, 50 years, has been with weird problems. I just try to plug along and ask questions when needed. Thanks for your help.
                sdetweil @RonR
                @RonR mine matches yours, since 1974… not so much weird as exciting newness
