    MagicMirror crash core.xxxx
    5 Posts 2 Posters 456 Views 2 Watching
    • htilburgsH Offline
      htilburgs
      My MagicMirror currently keeps crashing and generates core.xxxx files in the MagicMirror folder.
      When I open the file with gdb, I get this:
      gdb) core core.279811
      warning: Can't open file anon_inode:[io_uring] during file-backed mapping note processing
      [New LWP 279811]
      [New LWP 279819]
      [New LWP 279842]
      [New LWP 279818]
      [New LWP 279820]
      [New LWP 279812]
      [New LWP 279822]
      [New LWP 279841]
      [New LWP 279821]
      [New LWP 279824]
      [New LWP 279840]
      [New LWP 279830]
      [New LWP 279843]
      Reading symbols from /home/pi/MagicMirror/node_modules/electron/dist/electron...
      (No debugging symbols found in /home/pi/MagicMirror/node_modules/electron/dist/electron)
      [Thread debugging using libthread_db enabled]
      Using host libthread_db library "/lib/aarch64-linux-gnu/libthread_db.so.1".
      Core was generated by `/home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js --ozone-platform=wayland'.
      Program terminated with signal SIGSEGV, Segmentation fault.
      #0  0x000000556a30595c in uv.loop_interrupt ()
      [Current thread is 1 (Thread 0x7f94d2b020 (LWP 279811))]
      What is going on?
      (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
      htilburgsH S 2 Replies Last reply Reply Quote 0
        htilburgs @htilburgs
        I rebooted my MagicMirror and the “problem” doesn’t appear anymore now. Hope it stays this way, but still wondering what has happened.
          sdetweil @htilburgs
          @htilburgs sounds like a bug in electron. Not unheard of
          htilburgsH 1 Reply Last reply Reply Quote 0
            htilburgs @sdetweil
            @sdetweil said in MagicMirror crash core.xxxx:
            Not unheard of
            hahahahaha ;-)
            • htilburgsH htilburgs has marked this topic as solved on
              sdetweil @htilburgs
              @htilburgs and you can erase the core files
